maintenance free-ish SWA to PVC/Rubber flex join ideas
Good morning all
Joint outside not underground and within housing.
It is not possible to redo the cable segment (sadly).
What could be a solution to join small csa 3core SWA (armour not acting as CPC) to some PCV/Rubber flex and that would be maintenance free (-ish … as in it could be inspected but with great inconvenience).
What about a galv through box SWA gland in one end, stuffing gland in other and some push fits ?
Thought about crimping (as all stranded) but  couldnt solve armour bit  and enclosing joins in small adaptable box.
Any ideas please
Habs
  • It's what I would do but probably with a plastic box e.g.Wiska. I have no idea why I prefer plastic boxes even in dry conditions.
  • kfh:
    but… in that case what to do with the armour which needs continuity ?
    edit: forget that daft question of mine above (use standard fly lead from earthbar to CPC on cable etc)
  • The water bore hole guy would tell you to use a resin joint kit.
  • How about filling a wiska box with ‘magic gel’ and then claiming it's a ‘compound filled or encapsulated joint’ under 526.3(ii)?
  • psychicwarrior:
    kfh:
    Wiska earthing plates.
  • in that case what to do with the armour which needs continuity ?
    Use on of the brass earth bars for Wiska boxes intended for providing a connection to the SWA gland.
  • thank you all.
