Hi.
With reference to 100 Volt audio lines of a public address system, would the interconnecting cabling be considered Band I or Band II?
While the audio signal is not 50 HZ, I would call it AC, and hence the voltage might suggest Band II.
For obvious reasons I would not want to run audio with mains voltage wiring, so the audio may have to go in its own containment as it cannot go in the Band I containment either.
It will be wired in 300/500V rated cabling in any case.
What are people's thoughts on this?
Thanks.
