100 Volt Audio, Band I or Band II?
Hi.
With reference to 100 Volt audio lines of a public address system, would the interconnecting cabling be considered Band I or Band II?
While the audio signal is not 50 HZ, I would call it AC, and hence the voltage might suggest Band II.
For obvious reasons I would not want to run audio with mains voltage wiring, so the audio may have to go in its own containment as it cannot go in the Band I containment either.
It will be wired in 300/500V rated cabling in any case.
What are people's thoughts on this?
Thanks.
  • and that is why the mains cables will be  insulated and sheathed, or armoured according toi the environment, - assuming you will allow the mains to be bare and insisting the speaker cable needs to be bomb proof is the wrong approach.
    I
