Calling All Plumbers.
I was recently called to an immersion heater problem. The top entry 27 inch immersion heater was installed in a new copper cylinder that was much higher than the immersion heater length. I reckon that a 36 inch immersion heater could have been installed. What was the logic of installing a new copper cylinder where the bottom quarter of cylinder water will never be heated?
  • I reckon that a 36 inch immersion heater could have been installed.
    Assuming it is not in the middle at the top, pointing directly downwards, it will be at an angle. You don't want it too near the walls at the bottom (3 to 6 inches is good), also you don't want it very near the indirect coils, if the cylinder is also heated indirectly.
    The only way to know for sure is ask the manufacturer of the cylinder what length they recommend for the model of their cylinder, or find instructions online.
  • What was the logic of installing a new copper cylinder where the bottom quarter of cylinder water will never be heated?
    How much space is there between the top of the cylinder and the ceiling/cupboard top? Just thinking about maintenance...
  • More info please? If the immersion heater is the only means of heating the water, it seems a bit odd. I take Andy's point, but if space is an issue, then side entry is a possibility.
    If the immersion heater is just for occasional use (as when my thermocouple failed a couple of weeks ago leaving me with a distinctly tepid shower) it doesn't matter.
  • There is plenty of room for a 36 inch element. The old tank was perhaps 200 litres + as it was a two element economy 7 type, one side entry top and another at the bottom. The new cylinder can easily take a 36 inch element leaving say 5 to 6 inches at the bottom. There is no internal coil as the house has no gas or oil boiler.
