fuse issue
trying to source this is proving to be a bit vague, does anyone know where i can get them in the UK?
  • James
    Might be worth asking one of the admins to move this to the Wiring and Regulations section where they seems to be generally more activity.
  • Better to @ mention one of the admins  and we can move it there Wink. Double posting duplicate content in different forums is not something we encourage. Slight smile
  • Noted and edited Thumbsup
  • Probably need a bit more to go on (size, rating, brandname perhaps) - but looks similar to some of the Bussman ones to me (e.g. SAFEloc range) - if perhaps an older version judging by the moulding. RS usually have a good range of less usual fuse carriers - e.g. https://uk.rs-online.com/web/c/fuses-circuit-breakers/fuse-holders-accessories/fuse-holders
  • perspicuous may have one in his workshop.
  • It seems that went bang with a vengeance. Do you especially need to replace like for like? And risk the same happening again? Or perhaps get something a bit beefier.
  • I have emailed a link to the stockholder of rare and obsolete electrical equipment as he doesn’t seem to pass this way these days.
  • Looks like a slidelock fuse, used to use them on the meter dept of the DNO I used to work for to protect contactors, also used in street lights, Bussmann make a similar one.
  • I live and learn, Google actually suggests a different spelling
    www.thefusecompany.com/.../k511fw-5amp-415volt-slydlok-fuseholder-black-k-range.php
  • I have one that is very similar and is marked "Lawson Fuses Clip Fit" 63 Amp. 415 Volt 5W. It can be held onto a back plate by a screw or a D.I.N. rail. The weakness here is the single terminal screws that may come loose.
    Lawson 63A Clipfit Fuse Holder Black (LCF63 FCFC BK) | CEF loose.
    The O.P's fuse seems to have been running hot for a considerable time. Overloaded perhaps?
