Washing machine in bathroom
Hi all,
I am looking to install a washing machine in my bathroom, and was hoping I could get some words of advice on the electrical regulations involved.
It will be along one wall, a washing machine enclosed in a unit, a sink beside it, with an enclosed shower on the other side of that. The washing machines power supply will be running through the wall beside it and will be accessed from another room. The gap between the shower and washing machine unit would be about 750mm. There is an rcd on the fuse box.
I have been trying to understand the electrical regulations involved, and as someone that doesn’t know this stuff well I am a bit confused by what seems to have been changes in the last few years, and what is current/old advice. I have read that there needs to be a gap of 3m between a plug socket and a shower/bath, possibly less with a wired/enclosed socket. But this would be run through the wall beside the washing machine and accessed from a different room anyway, so would be okay?
Then the washing machine itself would be an integrated one in an enclosed unit with a door.
I felt like this would protect it from any splashes from the shower. The power supply would be from a different room so that shouldn’t be an issue. All circuits are protected by rcd. I am not looking to rent this flat out, am just living in it. However, I do understand that when I do come to sell it, it being able to pass an EICR would be needed for anyone looking to buy to rent.
I guess I was hoping for advice on what electrical safety certificates this could potentially pass? Im not sure how much, if any, wiggle room there is with things like the 3m rule of shower to washing machine? Or if it’s that even the rule, and if the 3m is just for power sockets.
Sorry this is so badly worded. I hope I’ve gotten the relevant information through. I would just massively appreciate any feedback on where this plan would sit re: electrical safety regulations!
Many thanks,
Chris
  • There is no wiring regs problem with a washing machine in a bathroom. But unless it is a large bathroom, to meet UK regs you probably have to cut the plug off and wire it to a fused spur to avoid there being a 13A socket being within the 2.5m permitted range of the bath. Making a plug sized a hole in the wall and using a socket in the next room is dog rough, and may make isolation for maintenance/ emergency difficult. Depending on the building, damp air sounds and smells from the bathroom may be unpleasant addition to the other room, and wood and plasterboard studding does not appreciate damp internally.
    Arguably a socket in a cupboard with a (lockable?) door that remains firmly closed during bathing may achieve the same end more neatly. (areas only accessible using tools or a key are considered to be outside the bathroom zones, as out of reach of bathers.)
    The better solution is that there is no doubt that a sensibly located fused spur is OK in a bathroom, so long as 60cm plus from edge of shower/bath and in a place unlikely to be splashed during reasonable use of the bathroom - though that may include considering kids playing ..  . (example of a fused spur  They are not much more waterproof than a plug and socket, it just cannot be easily unplugged and used for something else.)
    Note that the 2.5m length to any 'normal' socket has to bend like a cord round any fixed obstacles, such as shower screens,  or permanent furniture, so may sometimes be achievable in a room of slightly less than 3m.
    There may be further reasons not to do this however, unless the bathroom is well ventilated and/or the washing machine makers recommend this for your model. If the  bathroom is at all prone to condensation it is likely any  machine designed for kitchen use will have a short and rusty life.
