As above. Are mains linked detectors mandatory or are battery operated acceptable.
Thanks Gary
The regulations do not stipulate the type of alarms (such as hard wired or battery powered) to be installed. Landlords should make an informed decision and choose the best alarms for their properties and tenants.
So it depends on the Fire Risk Assessment, so for example will tenants hear an alarm on another floor on the escape route?
Thank you. That was how i read it on i think was a smoke angel site. I had it in my head they had to be mains.
Gary
Contact a supplier such as AICO for guidance. Last time I looked, wired smoke and heat alarms are only permissible in England, no battery types are allowed in rented properties and they must all signal an alarm to each other wirelessly. They don't fall under BS7671 apart from the mains connection.
That was my understanding as well but thought I might be getting confused with new work. The Government document in the link does not say that. It says batteries are acceptable although it is dated 2015. It says the same on another site i looked at as well which is why i questioned it.
Gary
I think it's got more confusing as technology changes - battery-only used to mean a PP3 that would go flat after a year and could be removed by tenants on a whim and mains only ones could be defeated by a power cut (or switching off an MCB). But now we have the option of mains + backup battery (or capacitor) or even battery ones that where the battery is good for the lifetime of the detector (10+ years) and sealed in so it can't be removed - so all the pros and cons can dance about a bit.
