This discussion is locked.
Charge for changing an existing meter and not a smart meter?
Hi all,
I need advice for a possible meter change.... just a backstory so far, I've had a consumer unit change for my property from my old DB to ( FuseBox F2014MX 14 Way RCBO Consumer Unit + Surge Protection) and my Electrician has recommended that I get a 100amp rated main fuse (the existing one was 60amps). So I called the DNO and requested the fuse upgrade, but their reply was that I needed to change the electricity meter to 100amps as well, as well as change the meter tails to 25mm. I thought okay... so I get on the phone to my energy supplier and ask for the meter upgrade as well as tails. I opted to not get a smart meter, as I have heard about their unreliability, I just wanted a conventional meter with 100amps. The guy on the other end tells me its going to cost £140 to keep the old-style meter with 100amps but will be free with the smart meter. Is this correct, do I have to pay to upgrade my meter with the old design vs not paying for a 100amp smart meter, I don't understand why one is free and the other isn't. Someone please enlighten me....
  • The only people who can answer that with confidence are your energy supplier, as they will provide and fit the meter.
    In reality neither figure (£00 or £140 ) is the cost of the meter or the fitter driving there.  The meter itself may be £40 to £70, and the fitter will be paid by the hour. I suspect there is a deliberate policy to subsidize smart meters to encourage their installation, and that has the effect of making not so smart ones look a lot more expensive.
    But first I'd question the  need for all this.
    Have you added a lot of new loads to your house as well as the new consumer unit ? If not, if it ran before without blowing a 60A fuse, it still will, and there is not a lot of point in changing.(the meter will be changed for free when it reaches end of life.)
    Dividing the same load among more circuits does not change it,  all it does is make fault finding and zone isolation a bit easier.
    regards Mike.
  • It should not need explaining.
    Upgrading to a Smart Meter is Part of a rolling programme and eventually you will end up having one, installing a replacement dumb meter is unnecessary work as far as your supplier is concerned.
  • I'm sticking with my 'dumb' meter - I'm already penalized for not paying by direct debit and insisting upon a quarterly paper bill.
    If they are charging me for a service, then I insist upon getting what I pay for. Smart or dumb, there's no cost advantage to the consumer either way other than the supplier not knowing when you consumed your units if you have a dumb meter and cannot therefore be charged a premium rate for usage at a certain time of day. Once you have a smart meter you will lose complete control since there is no competition and nothing to really stop them automatically switching you to a premium rate as and when they please.
  • Your supplier wants to fit a smart meter.  It makes their billing easier and more accurate, and the government is pushing them to do it.  If you accept a new smart meter, they will come out and fit it for free.
    Your supplier no longer wants you to have a "dumb" meter.  if you want a new one, then you can pay their call-out fee to come and fit it.
    Sounds fair to me.  If you want someone to do work for you, you're going to have to pay them to do it.  Unless it's something they already wanted to do anyway.
  • Smart meters, and the act of fitting of, are in no way 'free'.
    Just needed to get that out there least it might mislead.
  • The meter belongs to the supplier, ultimately if they want to fit a Smart Meter to replace a dumb meter they can fit it.
    That doesn’t mean it will always work as a Smart Meter, which may be an issue for both the consumer and the supplier unless they can be piggybacked onto the consumers internet connection.
    The original poster has currently has three choices:
    1. Have the meter tails upgrade and Smart Meter free of charge.
    2. Pay to have the meter tails and a replacement dumb meter.
    3. Do nothing.
    Option 1 means the job is done and finished.
    Option 2 doesn’t mean the dumb meter won’t be replaced with a Smart Meter in the near future.
    Option 3 postpones option 1.
    Now in all honesty, just say how many people you know personally who are having more issues with Smart Meters than they ever did with dumb meters?
  • Once you have a smart meter you will lose complete control since there is no competition and nothing to really stop them automatically switching you to a premium rate as and when they please.
    How do you mean? I thought you'd still free to swap suppliers/tariffs once you have a smart meter - and any recent one will be SMETS2 and so be able to communicate with your new supplier just the same. Once fixed contracts are over you'd yet plonked on a standard variable just the same - having an old meter won't prevent that. If anything the option of more favourable tariffs (remember the free electricity on Saturday or Sunday one?) will only be available if you did have a smart meter.
  • No competition in the mktplace thanks to OFGEN. So no competitive tarriffs available right now. And I can't see this improving any time soon.
    See my latest post here -
     https://engx.theiet.org/f/discussions/28618/turning-off-costs-why
    And there's worse to come.
    Britain’s power networks need at least £54 billion of investment to connect up new offshore wind farms this decade, according to National Grid.
    Hundreds of miles of onshore cabling will need to be built as part of the plans set out yesterday, which would represent the biggest investment in Britain’s electricity transmission networks since the 1960s.
    The proposals were published by National Grid ESO, the FTSE 100 group’s electricity system operator, which is responsible for keeping the lights on and advising on the design of the power network. Subject to Ofgem approval the upgrades will be built by companies including National Grid, ScottishPower and SSE, and their costs levied on household bills.
    Offshore wind farm developers to date have each built individual connections to shore, an approach that has attracted opposition from affected communities and created bottlenecks in the electricity grid, resulting in wind farms being paid to switch off.
    The ESO said this approach had become untenable as ministers pursued a five-fold increase in offshore wind capacity to 50 gigawatts this decade.
    The proposed “holistic network design” is the first time there has been a co-ordinated plan for connecting offshore wind farms and ensuring that the power gets from where it is generated to where it is needed. The plans cover the connection of 23 gigawatts of new wind farms, requiring £32 billion of new offshore infrastructure. The ESO is still working on plans to connect up further new projects. The plans also cover onshore grid upgrades worth £22 billion to accommodate the full 50 gigawatts target capacity.
    A number of new onshore lines have already been proposed but ESO said the network would need further reinforcement with new links from North to South Wales, across northern Scotland, and from Lincolnshire to Hertfordshire. These routes are yet to be decided and could be partially offshore.
    ESO said its proposals would save consumers £5.5 billion compared with continuing the unco-ordinated approach. However, the proposals — which had been delayed because of concerns about opposition from MPs — were immediately criticised by campaigners against new pylons.
  • I'm already penalized for not paying by direct debit and insisting upon a quarterly paper bill.
    That appeared to be the case when I was changed to British Gas, but I spoke to them and they told me that it made no difference; nor would it make any difference if they fitted a smart meter. The reason quite simply is that the capped rate is the capped rate. No discount on my tariff for online/direct debit.
  • You can say the same thing for almost anything that is offered for free.  Somebody, somewhere, is paying for it.
