Novel use for a load bank !
A load bank is generaly used for load testing generators and other equipment.
Earlier today I saw one being used to inflate a hot air balloon on the ground. Once aloft it was heated by a propane burner as normal. It was very effective.
I have used a load bank as an emergency heater for a very large sports hall, that worked fine, never seen one used to inflate a balloon before though.
  • ah electric ballooning - maybe a greener method once we get off burning methane in power stations !!
  • The only problem is the efficiency is  about 40% in place of 100%!
  • They are a pretty effective way to clear snow and ice from a car park in mid winter too.
    regards, burn
  • That's different, out of curiosity any idea what kind of size the loadbank was?
    I've been asked to loan ours out a few times for odd purposes but its only 100kVA.
  • The load bank used to inflate the hot air balloon was 240 kw, but switched in steps and only run at 120 kw . When a balloon is completely deflated the propane burner cant be used. A portable blower powered  by a petrol engine is usual. A load bank is far more effective than a blower because the air is hot.
    The load bank used for heating a large sports hall was IIRC 500 kw, it worked excellently. Placed outside and directing heated fresh air inside via a doorway. All cold, damp, or stale air was thereby expelled. Once the building was ventilated and pre warmed, about 90 kw of portable fan heaters were used.
  • 2 x 600kW (pre-handover testing of a data centre's 600kVA generators).
    burn
