Current is varying between 2 phases and floating across each phase do tell me the remedies or fault in this case.
This needs a better description to be able to answer - what type of supply/generator are you dealing with and how far down the chain of generation inversion/transformation is it where you have this problem., how is this effect being measured (relative to what) and what is the loading and phase balance of the load ?
