Integral LED Lightspan IP20 IK08 Batten intermittent flicker issue
i've installed 2x of these https://www.toolstation.com/integral-led-lightspan-ip20-ik08-batten/p18251 in a customers garage about 15 months ago , so they've both been flickering here and there for 6 weeks now i've been informed. Anyway I was there today and they are working fine ,I tested the voltage at 243V ( the fittings are designed for 220-240) and made sure everything was tight, I also found  were a few dead spiders in one of the fittings.
I'm thinking it's a voltage surge especially as both fittings have a flicker ( it's a flicker rather than strobing) I also thought it could be moisture in the air but the garage is completely dry. i've hopefully added a video there too. look forward to hearing any of your suggestions.
1drv.ms/.../s!AhBJ8ZIRXm3We_ut-72SAy2SK_I
  • LED drivers/ballasts going phut or flickering seems to be depressingly common - whether damaged by something (surge?) or just the result of age and poor design/manufacture or something else I couldn't say. Both going the same way within a few weeks seems unfortunate, but far from impossible. I'd try a new fitting,,,,
