Voltage drop on a shower causing a light to come on
Hi everyone I was hoping someone might be able to help I came across a video on YouTube where when the shower was turned on it caused the bathroom light to glow while the switch was turned off. The person later explained it to be a voltage drop on the shower but to my understanding something like that wouldn't have that kind of effect ant guidance would be great thank you.
  • Cant see any comments at all just a picture of a lamp in a holder accompanied by annoying music. Could be almost anything - lamp in series with fan or another light fitting used to be a classic with decorators making a mess of loop through rose (aka 3 plate) ceiling fittings. I suspect that the use of phones to take a before and after pic have reduced this a bit
    Equally could be an LED 'filament' lamp and as above capacitance.
    I agree, shower  induced voltage drop is likely spurious.
  • Thank you. That is an LED lamp.
  • That is an LED lamp.
    agreed - e.g. https://www.toolstation.com/sylvania-led-rt-a60-filament-clear-gls-lamp/p85671
    Real filament (incandescent) GLS lamps (at least of the ordinary domestic type) generally had the filament as a flat semicircle at towards the top held up on a number of fine wires from a central glass post (or as an obvious coil in much older ones) - like this one https://www.easy-lightbulbs.com/products/gls-100w-b22d-bc-240v-philips-clear-light-bulb . The 'sticks' are LEDs trying to look like filaments.
    We're likely back to the capacitive coupling theory.
  • Okay so you reckon that the light is gaining an induced voltage from the shower circuit caused by capacitive coupling. Would this effect be increased with a higher voltage drop?
  • we lose a further 5 volts which goes down to earth and the neutral conductor.
    Erm, voltage is probably best thought of as a pressure difference between two points - volts don't travel as such. It's the current (amps) that flows - and flowing along something with resistance (which everything has) results in the pressure drop (voltage difference). Text book wise it's all just Ohm's Law. V=IR. You've got the same current flowing through all parts of this simple circuit - the overall current is regulated by  the overall resistance of the circuit (load and all the connecting wires) and the supply  voltage as a result is divided up across each component of the circuit - so the voltage of across each part in series adds up to the original supply  voltage. There's nothing special about the N conductor in this regard - it carries current and has a voltage difference along its length in exactly the same way as the line conductor.
