AFDD in a hospice??
Hi All,
We are currently designing a a new build extension to a children’s / young adults hospice and hoping for some guidance.
the extension will consist of 3 new bedrooms, kitchen, corridors, community room and a garden.
Firstly, we are unsure if a hospice applies to any of the buildings outlined in 421.1.7 our understanding is that is does not. So we have referred to Section 710 and referred to 710.421.1.7 and using annex A710 we have determined  the bedrooms do not require AFDD's as they are group 1  and all other rooms would fall under group 0 and require a risk assessment.
Look forward to hearing your thoughts.
  • To justify a 1k per fusebox change on safety grounds, instead of not doing it and spending the saving on some other more effective safety measure (perhaps new tyres and brake pads on the car ?) you need something like 1 in 1000 installations to actually kill someone if you don't do it, (assuming £1 million per life - you may double this if you like, it has little effect on the conclusion - then you need 1 in 2000 thousand fuseboxes to be deadly dangerous...) In the UK the rate of electrocutions and fires are nothing like that bad over any sensible period. In fact they are not even that bad in places where earthing is optional and wires aer twisted together instead of in connectors.
    By all means make the change on cosmetic grounds, or ease of use, or change of load, but  not immediate danger. It is important to keep a grip on the figures and why we do things.
  • a 10 way board with SPD and fully populated with RCBOs is about £150 have a look at Verso or CP FuseBox, Its the AFDD board that reach a £1K
    Good question on the CO alarm.  Yes people only fit them in a rented property if they have solid-fuel or gas appliances in as this is now a legal requirement but I do think that the average home owner should also follow the same rule of CO in room with  solid-fuel or gas appliances.  Additionally heat detectors should also be mandatory in kitchens.
    Another question for discussion
    In flat which does NOT have solid-fuel or gas appliances in the block of flats a that do have solid-fuel or gas appliances
    CO detector would also be beneficial as CO can enter from outside or from the communal areas.
    (To test the theory have a look at blocks of flats in your area, spot the exhaust flue on outside of building and then see how close it is to and airvent or window of that property or another property)
  • Sergio,
    Your detail all sounds great! ( In Theory), Now being a engineer based and living in Scotland where legislation now dictates that all dwellings must have hard wired smoke/heat/CO detectors and all interlinked or all interlinked but long life battery operated that comes at a big cost!!
    Firstly home owners, letting agents etc need to know about the legislation and when it comes into affect, and the Scot Gov made a right pigs ear of that so much so the deadline dates changed.
    Secondly the home owner, letting agent needs cash/funding to install the appropriate devices and pay somebody competent to do so.
    Thirdly the devices need maintained.
    Fourthly according to legislation a home owner may run into issues if they try to sell the property without the right number/type of detectors and all working. So surveyors may identify no appropriate detection that could prevent a sale going thru or more likley the buyer will want a discount on selling price.
    Now personally, I went out and bout wireless 10 Year battery units, so three CO detectors, two fixed rate of rise heat detectors and five smoke detectors, all fitted in correct places based on the legislation, the devices cost me just over £700!!
    As Im capable of installing myself the labour charge was nothing, so far so good.
    But what "Benefit" is there in this legislation to me and what you imply? and please answer that question. As a time served craft electrician with the practical and qualifications I have now and working in the fields of compliance and standards of work. Im sure you can guess the electrical installation in my home is as good as it can be, designed, installed and maintained by a competent person. I cant say no electrical from of ignition would never occur but its certainly as low as it ever could be.
    Under the old Scot Gov legislation and being competent I had battery smoke and heat detectors and CO detectors anyway, and when the alarmed to say battery needed changed I did that.
    So Im now £700 + out of pocket and for what benefit?? as the condition of the electrical installation in my home and equipment hasnt changed. But I have complied with the Law.
    My gripe and complaint and issue is, the cowboy electricians/contractors poor design and use of incorrect materials and non compliance of stadards for electrical installations will still all happen and those property owners that go down that route will certainly not be fitting £700+ of detection equipment after all when they work the fire has already started.
    So to me its like saying everybody fit seatbelts and airbags but do nothing about driver skills and competency and road conditions. By the time tthe seatbelts and airbags have worked you have already crashed the car.
    As members of the IET and those of us that may influence policy and legislation is lets make the installations safer so some of these modern devices are not needed, rather than how things seem to be accepted of lets put in these devices because we know the deisgn/installation and verification of the installation is crap.
    Lets get this in the right order first please.
    Cheers GTB
  • So Im now £700 + out of pocket and for what benefit?? as the condition of the electrical installation in my home and equipment hasnt changed. But I have complied with the Law.
    Move south, young man! ;-)
    Well, would you drive a 90-odd year old car with no belts (forget airbags!), rigid steering column, no crumple zones, etc?
    I agree with everything that you say. Now I really must get around to installing those alarms just in case the house catches fire at night. (What use are alarms during the working week?)
    Yes well, cheap tyres are available too, but I wouldn't put them on my car.
    You may be correct, but I think that such an installation would not comply with the building regs.
  • By all means make the change on cosmetic grounds, or ease of use, or change of load, but  not immediate danger. It is important to keep a grip on the figures and why we do things.
    Mike, I fully take your point and to some extent it depends upon the budget which is available.
    I don't think that I am in immediate danger, but JP may disagree because I have Federal Electric boxes!
  • CO detector would also be beneficial as CO can enter from outside or from the communal areas.
    AFAIK the requirement is only around 300mm (about one brick and a window frame) -  guess the point being that the large volume and turbulence of outside air dilutes the gases fairly rapidly - unlike a leak into an interior room where the products of combustion can build up over time.
  • Chris,
    Thanks and yes I did smile at your comments and glad we think alike, just one wee thing though property prices are so much lower up here, so far larger property and land than what one gets down south!! so maybe thats where I found the £700 from!
    Cheers Gareth (GTB)
  • Hi Everyone,
    Thanks for responses (although we slighty drifted off topic haha!)
    We have proceeded by any rooms that classify as a medical location and would cause serious harm is there AFDD was to nuisance trip we will not install (like bedrooms etc) and areas where the above does not apply like corridors we will be installing AFDD's to comply with 421.7
    Joe
  • How will you test the AFDDs?
