Alternative solar supply available at point of use Domestic kitchen
Hello newbie :
Imagine Domestic kitchen Usual array of sockets and under counter appliances
Wish Introduce  Alt solar supply sockets alongside existing grid supply sockets , Thus : User can select alternative ( solar ) supply as opportune arises  at point of use ( battery storage/ inverter system)
Eg plug microwave to alternative socket  as power opportunity ( battery charge is available )
(Alt supply sockets are entirely dedicated from inverter as typical OFF grid system )
Question  Is there  anything in regs preventing this ; Thought: The sockets must be somehow labelled / identified as alt supply  Any ideas to meet regs?
Remark : similar to external generator supply but with NO changeover switches . Outlets are dedicated
thanks Ms Otis
  • Squirrel has eaten though +ve dc cable of solar array Now died but  attached conducting to metal frame ?  So anyone touching that frame is  surely NOT exposed to shock unless they also grab hold of any exposed negative side of the PV array .?  2 squirrels
    Earthing of PV frames question is far more involved than can be communicated in a discussion forum, and has NOTHING to do with damage to DC cables. !
  • Also, it enables the effective functioning of the d.c. isolation fault detection system within the inverters; it reduces the hazard of electric shock due to leakage currents; and it harmonises the UK practice with the international standards.
    i.e. EAWR which applies to most electricians (although not always "DIY") working on PV systems.
    Regardless of DIY, the designer of an installation has to ensure safety during maintenance ...
  • Thankyou again:  Perhaps thats more practical : Achievable  my idea looks too difficult : Still like it has merit.
    Reflect : any chance to protect the planet  We must simply learn to live with less
    All my kitchen appliances would be plugged to off grid . ( bar fridge)  Consumer faces choice every time and a minor effort to do so. Do we really need to run that washing machine now ? Its in your face :  Off grid living I hear is something you get attuned to . Grid tie  ?  Convenience / forget./ Carry on as normal.   Maybe some chance to equal summer winter out :Size this off grid  it to run only two appliances at a time in winter. Abundance in summer Mow the lawn. whatever.
     Remain reluctant to have a lithium battery in the house: That  has forced outhouse and underground  complications. Costing beyond my abilities and suppliers it seems  Oh  Electric bus in wimbledon caught fire recently. First ev car on charge in front of house to catch fire ?  The genie is out the bottle   Sure many must now be considering battery fire risk and so to outhouse.  That area is the too difficult box.    .   So I thank all and especially yourself  for all the opinions and advice. Life is too short .
    Now doubtful in both cerebral Hemispheres  Ms O
  • Grid tie  ?  Convenience / forget./ Carry on as normal.
    If you can still have the "experience" if you like - e.g. use a smart meter display to see what you're using (both instantaneously and over say a day) and see if you can keep to some limit. Or if you like some financial incentive, switch to an Octopus Agile tariff and see how good you are at shifting your consumptions to times of excess generation and/or low demand.
    Very few off-grid systems will rely on PV alone (not at these latitudes anyway) - the seasonal (not to mention daily) variation is huge. Traditionally domestic sized off-grid systems were backed up with a conventional generator, these days perhaps some other renewable that's better in winter - usually hydro or wind.
    Buses and cars are always catching fire - with petrol/diesel ones it's so common hit hardly makes the news (unless it takes out a large multi-storey car park). I suspect in the end EVs will be no worse than what went before in that respect. I take the point you wouldn't want to store 50 litres of petrol inside you house though.
    One thought - some of the commercial (grid tied) battery storage products are designed to be mounted on an outside wall - if you've got a nice solid masonry wall without openings near by, that sort of approach might provide some reassurance. Not suggesting you buy one of their unit, but you can be inspired by the principle.
    Keep pondering - it took Edison quite a few attempts before getting even a simple filament lamp right, but with determination you get there in the end.
  • If you're worried about fires, then either:-
    • Go old school and use deep cycle lead acid batteries.  They will be big and very heavy, but as they aren't in a vehicle, who cares.
    • Go up-to-date and use Lithium Iron Phosphate batteries, that are far less flammable than Lithium Ion.
    Although lead-acid (even sealed ones) have a habit of liberating hydrogen under some conditions - so if indoors need good ventilation to the outside - so still not ideal for a habitable space.
