Alternative solar supply available at point of use Domestic kitchen
Hello newbie :
Imagine Domestic kitchen Usual array of sockets and under counter appliances
Wish Introduce  Alt solar supply sockets alongside existing grid supply sockets , Thus : User can select alternative ( solar ) supply as opportune arises  at point of use ( battery storage/ inverter system)
Eg plug microwave to alternative socket  as power opportunity ( battery charge is available )
(Alt supply sockets are entirely dedicated from inverter as typical OFF grid system )
Question  Is there  anything in regs preventing this ; Thought: The sockets must be somehow labelled / identified as alt supply  Any ideas to meet regs?
Remark : similar to external generator supply but with NO changeover switches . Outlets are dedicated
thanks Ms Otis
  • Earthing of solar panels mounting framework   2 B or not 2 B ?  Protections ?
    Forget "ADS" style earthing and automatic disconnection as a means of shock protection on the d.c. side of PV - it just doesn't work. PV panels produce whatever current they produce (according to what the sun/clouds are doing at that moment) - there's no significant increase in current just because there's a short-circuit (to earth or any other way). So neither fuses nor circuit breaker are any use for ADS. In theory (and what's often done on a.c. systems with limited fault currents) you could have a N-PE link at the source and use an RCD for disconnection, but RCDs don't work on d.c. so that's a non starter for PV as well. Separated is a bit dodgy as it demands complete separation from other systems - which the battery charger (or conventionally an inverter) is unlikely to achieve to a sufficient standard. So all you're left with is SELV/PELV if the voltage is definitely within ELV range (won't be for a 4kW system), or double/reinforced insulation. So normally double/reinforced it is. If needs be you can add extra mechanical protection (e.g. conduit). You may still want to earth the frames for other reasons though (unfortunately I don't have the latest advise to hand - others here might know).
    panels proposed are 400w each x 10
    I'm probably getting ahead here, but what capacity of battery are you planning for? My circa 2kWp system can produce anything up to 14kWh a day (mostly a lot less, but I have had 14kWh on a few occasions and only a bit less on a larger number of days and so on) - so I'd guess your maximum could be in the region of 28kWh in a day - maybe more as you're a fair bit further south. I'm guessing the thinking is that it would be a shame to waste the power just because the battery was full. Can you presume that the battery would be discharged at dawn, and or there would be some reliable load during the day? Or would you want a bit more capacity so you could store excess for another day?
    Even if we work with wanting say 28kWh usable capacity, most batteries don't like going from fully charged to fully discharged - chemistries differ but I think LiIon generally want to say within the 20%-80% band for a decent lifetime - so you can only use say 60% of the nameplate capacity. Thus to get 28kWh you'd need about 47kWh nameplate. At 48V that's about 980 amp hours (Ah) worth (or nearly 4,000Ah at 12V) .... that's not going to be cheap (or small).
    Of course there's room for compromise - work with a lower storage capacity that would take all the generation over say 90% of the year so you're only wasting power on the few sunniest days. All choices to think about during the design process...
    That's another plus for the grid-connected approach - any excess you can do something useful with - i.e. export to the grid; and you can be paid for it - I think most smart export tariffs pay in the region of about 15p/kWh at the moment. That can add up over time and helps to soften the capital costs.
    Grid connected battery system are typically a lot smaller (mostly to make them less unaffordable) - often sized something in the region of one day's consumption (say 5 or 10kWh) - and there's a lot more to-ing and fro-ing with the grid to make up the differences - exporting on sunny days and importing on dull ones. In effect use the grid as a big (and not too expensive) battery. It might not always be there, but that doesn't stop you taking advantage when it is.
  • Put that aside  I must still have clear idea to get the cables laid before anything
    and I think you still have the issue with the underground cables if you're running the d.c. PV side through them - the earthed armour approach doesn't work as there's no ADS, and the voltage will be too high for SELV/PELV.
  • There is a previous thread here  Solar Cable PV1-F in ducting underground.
    on solar cables carrying DC  underground may be worthe read too.
  • dear all I, In conclusion I am  taking away There is no virtue in earthing the mounting system of a  dc PV array ? Whether 200V or so or not Since there is no conventional fault protection to dc
    So dont bother . Best is run in protective conduit and fingers crossed . ( Though with all the caveats about burying seems most go to nail it around some fencing as better?
    I wanted this lot to be in my garage firstly out of latest concern LI batteries volatile fire issue ? Does anyone else think house insurance policies will become more adverse if you have one in teh house ?  It will surely happen soon some  ELV car will ignite the issue .
    Anyway so now pondering to build a some outdoor housing closer to the house for this lot . My supplier quoted my £4000 for a proprietary thing .! No way  Any ideas.  But that still leaves another ac cable going to the garage as was goin to do same thing there " Independant sockets /  lawn mower / charge my bicyle battery  etc.   Could think of a changeover switch for that Existing ac cable going to garage.
    A simple outhouse for the inverter batery would greatly reduce trenching  Simple small ( ugly changeover switch for garage might have to tolerate.
    ANDY can I please ask separately on how you sized your system . My supplier ( recipe) has simply sized for a standard off grid whole smaller house.  I dont all that.  In particular how do we estimate recharge times for li batteries
    I still want to go for this anyway . In five years time this system  " Grid /essential independence/ Select at point of use/  will be a regular choice !   Grid is wobbling / EDF nuclear power is cost trebling  Prices for electricity are going up and up.
    ciao MsO
  • ANDY can I please ask separately on how you sized your system
    It was just the largest we could fit on the available south facing roof space, given the power of the panels available at the time (2010), working around roof windows, a solar thermal panel and shadowing from a possible chimney re-build (which didn't happen in the end, but..)
  • In conclusion I am  taking away There is no virtue in earthing the mounting system of a  dc PV array ?
    That wasn't the impression I was trying to give. There are potentially reasons other than shock protection from the d.c. side for earthing (or more likely, bonding) PV metalwork. I think you need someone who's read the latest version of Code of Practice for Grid-connected Solar Photovoltaic Systems (I appreciate yours wouldn't be grid-connected as such, but the d.c. side would essentially be very similar). The answer may well still be the same, but it's better to be sure.
    I do feel you might be making thinks unnecessarily difficult for yourself. While having what's in effect an off-grid system alongside your normal grid-fed installation is fine in principle, a lot of the details (e.g. remote battery and so running LV d.c. though long and/or underground cables) do create difficulties. By comparison, a grid-connected system would "design out" many of the problems, be a lot simpler to install and I think still have all the features you want (including being able to work when the grid has failed). As an added bonus you'd have your own power available throughout the installation (not just on the special circuit in the kitchen) and be able to take advantage of the grid (e.g. to export excess power, at a profit) when the grid is there. Power wise you could then run a single SWA cable out to the garage and use that both for the battery storage system and anything else electrical (lights, sockets etc., maybe even an EV point in the future). Grid connected battery storage systems (complete with islanding relays to keep your installation running when the grid fails) are commercially as packaged (and type approved) solutions. Maybe give it some thought?
  • Andy could you please itemise your system
    1. total wattage PV array  ( assume just simple PV array )
    2. KW size of inverter
    3. Battery voltage and Ahr capacity *assuming Lithium ?
    4.In winter how long do you expect to recharge this battery system
    5. What appliances did you expect to run from your inverter size ?
    Thinking a 3KW inverter rating generally wooudl easily run a washing  machine with surges  and enough  to spare   ? estimate ?
    TO ALL   Earthing of solar panel framing Any other advance please . If none i'll do it any way just belt and braces but  I cant see why .
    £75 for COP ??   Anyone else give a verdict on efficacy of earthing  simple dc solar panel metal mounting systems ?  Issue electric shock maybe 200v +  DC  ? Scenario  ?   ( Trying to imagine foreseeable s/c  )  Squirrel has eaten though +ve dc cable of solar array Now died but  attached conducting to metal frame ?  So anyone touching that frame is  surely NOT exposed to shock unless they also grab hold of any exposed negative side of the PV array .?  2 squirrels There is NO current path through the body unless person does that ?   This in  too difficult box to get this installation on the road  OK I will run an earth wire to the roof mounting system  for looks .
    Ms O
  • Hi Anne. The earthing and bonding requirements for the array frame depend on the following factors. You need to assess whether the frame is an extraneous-conductive part or an exposed-conductive part, according to the definitions in BS 7671. You also need to determine if a lightning protection system (LPS) is necessary, or if functional earthing is required for the proper operation of the system.
  • Also, it enables the effective functioning of the d.c. isolation fault detection system within the inverters; it reduces the hazard of electric shock due to leakage currents; and it harmonises the UK practice with the international standards.
    I've only got a simple grid-tied PV system (2.16kWp (9off 240W panels), with a 2000W inverter. No battery. It just supplies the house in general, any deficit automatically made up from the grid, any excess exported. (To some ways of thinking you could argue I use the grid as a battery.)
    Overall it generates around 1800kWh per year - although that might average to around 5kWh/day, it's very variable with both season and daily weather. May/June this year were pretty sunny and I was getting around over 300kWh/month (i.e. around 10kWh/day on average) Dec/Jan was rubbish - barely 1kWh/day on average - many days with next to nothing at all - often several days in a run when it's foggy or the panels covered with snow.
    If it help, here are a couple of screen shots from my (emon based) monitoring system (it's not the most accurate in the world, but does give an indication). Blue lines show local demand, yellow PV generation (so where there's yellow above blue, I'll be exporting to the grid, blue above yellow means I'm importing).
    June-ish:
    Dec-ish:
