Need double PLUS single white plastic mounting box.
Can anyone suggest a source of surface mounted white boxes to accept a double accessory (eg twin 13 amp socket) AND a single accessory  (eg fused connection unit.)
A quick google suggests fairly ready availability of steel boxes for flush mounting, and also of dry lining boxes for fitting into plasterboard, but nothing suitable for surface mounting.
  • I can't say I've ever seen a 2+1 pattress either. - I suppose most of the time you can get adequate results just by installing a single butted up to a double.
    Only other thought was to use something like a 3 gang Euro faceplate and put two sockets modules plus a fuse module and 20A switch module in to that on a conventional 3G back box.
  • I think marshall-tufflex do it but I can not find it on their web site.  Might be worth given them a phone call.
    01424 856600
