Loop Impedance Tests
I did a loop impedance test today at a garage socket with ATT on and got a measurement of about 250Ω, I did it again without ATT and measured about 2.5Ω. I have noticed small discrepancies before, but never on this scale. I did repeat the tests, and am fairly sure I was reading the display properly! The house is PME, presumable exported to the garage. I didn’t have time to investigate further, and am going back on Monday so can look into it further then. I am wondering what could cause such discrepancies. My meter has fairly new batteries in it.
  • Depends if you got on with the plumber or not Slight smile
    As you probably realise most modern testers pretest and if the full test is likely to take the touch voltage over 50 volts they abort the test, but the older testers like Robin don’t they just go for it utter regardless.
