Unfamiliar electrical schematic symobol
I've been working with electrical schematics for quite some time, but I recently stumbled upon symbols representing loads that I'm not familiar with. Are these new additions or have they been around, and I've somehow missed them? Any insights would be greatly appreciated. Thanks!
  • What this shows me, to work safely with customers or contractors digrams, requires the diagrams to include a key.
  • If the cup is facing the wall, the symbol looks more like a plug with a stump of flex.
    Just some context, this is schematically how a "plug contact" (bottom) in a "socket receptacle" (top) ought to be shown (ISO 7000 - 0354)
  • requires the diagrams to include a key
    Not required for the symbols that conform to the standards, though, only for symbols not conforming ? Or at least that's the idea.
    Not just being awkward, I've worked with schematics that would require sheets for the key alone, and to keep referring back isn't productive.
    Same with colour code that's been harmonized for a very long time now - why do people invent their own?
  • probably in some cases because the standard is not readily available - see  that thread about free standards, and in the case of colour codes, has to suit the cable you can actually get- which in defence electronics at least  tends to be dominated by AWG sizes and US color codes. (red and black for DC +/- anyone ?
    And for things like logic symbols, because the BS ones are rubbish.
    M.
    But we have been talking about an isolator symbol, which is shown in BS 7671 itself, and also in IET Guidance, so it's really not "hidden away" anywhere?
    Whilst it doesn't cover all the ISO 60617 symbols (the annual subscription for that being in the region of £600). most of the common ones can be found in the on-line browsing platform, e.g. for the symbols we are looking at, follow the link, click the radio button for "graphical symbols" and search for "disconnector"
    What I mean by colour codes, is the 2-letter colour code (4-letter for bi-coloured insulation) for wiring diagrams (say I have a 20-core cable that I want to connect for controls - you're not limited by colour except that GNYE is reserved for PE/PB (or combined PE+FE/PB+FB) and blue ought, as far as possible, to be used to refer to neutral (as defined in Part 2 of BS 7671).
    Following the lead of BS EN IEC 60445, We've put the BS EN IEC 60757 colour codes in Table 51.1 of BS 7671 now, so there really is no excuse regarding access to the standard when preparing diagrams:
    BK - Black
    BN - Brown
    RD - Red
    OG - Orange
    YE - Yellow
    GN - Green
    BU - Blue
    VT - Violet
    GY - Grey
    WH - White
    GNYE - Green-and-yellow
    Only because they are never taught. Just like most people would gravitate towards 'V=IR' rather than 'U=IR', and 'live and neutral' rather than 'line and neutral'
    Sometimes the ANSI "NAND" or "AND" symbols end up being used for socket-outlets on architectural layout drawings/floor plans.
  • It's a TP isolator. The Architectural ACAD symbol. If you zoom in on the schematic you can see the handle at the top ; the three diagonal bars donate three phases
    regards burn
  • The Architectural ACAD symbol.
    I'm not 100 % sure of the alignment with IEC 60617?
    The OP says it's on a schematic, and the later post is a schematic ... therefore I believe symbols should be as per IEC 60617-7-13-xx and be like the single-line diagram symbols I posted earlier (with "TPN" qualifier or similar)?
    However, if it's architectural (i.e. for use on floor plans and elevations to show rough location of equipment and controls in a room), IEC 60617-11-14-xx and a TNP (4-pole) switch, disconnector or isolator would look something like this, perhaps with a feature indicating it's an isolator.
    Can anyone confirm who has access to the current IEC 60617 database?
  • I didn't say it was in line with IEC 60617. Nowadays most of us working on larger scale construction projects have no choice but to use Autodesk products (ACAD 2D or Revit for BIM 3D modelling) and have to take what they give us.
    regards burn
  • The great thing about standards is that there are so many of them to choose from!
    Not in this case. BS 7671 specifically requires IEC 60617 (see Regulation 514.9.1)
