Standards interoperability, cable colour codes, Precedence & certification
Good evening folks, still a few familiar names on here so this should be an interesting discussion…,
More and more over the last few years I find myself in product production and the realms of ‘Placing on the market’ electrical equipment .
The sticking points are getting stickier with the advent of new technologies, systems and integrations.
So to dig straight in…
In the case of Solar & Battery installations BS7671 applies.
In the case of Switchgear BS EN 61439 applies.
In the case of machinery and associated control panels BS EN 60204 applies.
If we are building a product it will need certification CE/UKCA etc.
We need to choose the appropriate harmonised standard(s) / Directives etc.
BS7671 it isn’t a product standard and does not apply to ‘products’ that said it still has relevance in that there is little point placing a product on the market that fails to satisfy it’s requirements for installation.
I find cable colours are often a bone of contention with many.
We are all familiar with the standard colour codes in BS7671.
Battery systems are in the main Red - Black - though German vehicle manufacturers now seem to use Brown for negative ground and just about anything for the rest.
MCS now list Solar PV as  Red + White  -
BS EN 60204 has the following colour codes for presumption of compliance.
AC and DC Power Circuits
AC Phase and DC + / - : Black
AC Neutral : Light Blue
AC and DC Control Circuits
AC Live or Neutral via transformer : Red
AC Neutral Light : Blue
DC + – : Blue
Interlocks control circuits supplied from an external power source or remote panel : Orange
Panel Services Colour Coding (multicore)
Colour Coding for Panel Services (Single Core)
AC Live : Orange
So to the conundrum….
You build a panel (Product) that falls under the machinery directive as a result of its intended use and connected systems, BS EN 60204 supports the use of switchgear within such panels, The panel also has connection for PV array(s) and houses associated sealed battery storage
As a result, there are multiple standards, both harmonised for product certification and otherwise.
Black might be
AC Live of any phase
DC + or -
Red might be 12/24/48v DC +
1500v DC + from a Solar array
Any AC voltage derived from a Transformer etc etc
It quickly becomes apparent that no one standard fits.
If  60204 is chosen as the ‘Primary’ standard that would preclude the use of Red for Battery systems for example.
I realise we can build and certify anything as-long we are willing to certify and accept the risk in the product as the manufacturer.
Most electricians that I talk to just build their own panels and tend not to bother with the certification, however if we are to build and supply to 3rd parties that ‘luxury’ is not an option we can afford.
From the point of view of installing the panel, we can utilise the outward facing terminals standards, essentially this turns it in to painting by numbers for the installer.
Really I am thinking more along the lines of maintenance and the person(s) who have to work on it in the future.
How much reliance can we place on documentation and labelling vs conventional knowledge of electricians?
I remember Paul Skyrme once telling me if they dont know the colour codes they might be better stacking Tesco’s shelves, I understood the sentiment but how far and how much protection would this really offer in a fatality due to mis identification of cabling?
Apologies if this is a little rambling, it’s a reflection of my mind right now on this subject!
Martyn
  • The problem is actually worse if you are dealing with upgrades on legacy systems where older colour codes are still in use. Black can then also be neutral, red used to be earth in Germany and neutral here (Switzerland) was yellow.
    The key to the solution is documentation. The CE certification will record what standards have been used and the drawings, installation, operating and maintenance instructions will define colours and special requirements.
    There are three areas of injury/fatality to consider:
    If the system is installed and used according to the documentation and an incident occurs the supplier will be liable.
    If the system was not installed according to the documentation the installer is liable (unless the documentation is ambiguous).
    If a maintenance worker does not follow the instructions including isolation and testing for dead (which should also be considered ‘skill of the trade’ but usually isn’t, “shut up I know what I am doing” followed by bang) he or she has to take responsibility.
    This has probably confused things more but it is just my view.
  • Interesting discussion MartynD.  I see your thought logic on this.  Can I also add into the mix UK building regulation which can differ in England, Scotland and Wales.
    A classic example of a BS7671 vs Building Reg.  In a domestic kitchen, what is the minimum distance a socket/accessory can be from the edge of a sink?
    BS7671 does not cover this but other IET guidances/publications offer recommendations
    Building Regs do cover this.
    The answer is 300mm min on the Horizontal plain.
    I do think that BS7671 should have a entry for kitchen accessories even if it just states.   Refer to Current UK build regulation then the reg number eg 433.2.2
  • Except the BS7671 is not just for the UK - also used in Qatar, Malta etc.
  • I am not sure I remember what predated the Machinery Directive for colour codes in the UK & Europe, I think the first MD was 1989 becoming Law in ‘92.
    That said, I have worked on many very old machines and panels and cannot remember AC Neutral being black by convention outside of BS7671 in the UK.
    Interesting to hear the other colours from around the world.
    I was only talking to a friend with a new job in maintenance last week about ensuring compliance throughout upgrades & modifications.
    Sadly his place is beyond help on that front. He reports operatives using hands wrapped in rags operating faulty live switches to keep the plant running… I suggested he might be better looking for a better firm.
    I appreciate you laying out the liability areas, always good to see the overview to check ones thought processes!
    I am fairly confident I can differentiate function with a consistent addition of heat shrink colours.
    My working plan is to keep 60204 as the overriding standard with a few tweaks
    AC Power Circuits Phase Black
    DC + Black  with Red  heat shrink
    DC - Black  with White  heat shrink
    DC Control Circuits
    DC + : Dark Blue
    DC - :  Dark Blue with White heat shrink
    Plenty of thinking to be done yet but so far I am reasonably content with this approach and it seems easy enough to document and present for the Tech file and maintenance personal.
    Martyn
  • BS7671 also does not apply to products, control panels, CE certification etc etc
  • control panels, CE certification etc etc
    And also, aspects of wiring between parts of machinery as defined in the Supply of Machinery (Safety) Regulations, which are classed as part of the Machinery. BS 7671 stops at the supply to the machinery.
    And Northern Ireland, where Part P equivalent does not exist!
  • where Part P equivalent does not exist!
    ESQCR (NI) does, though, and this mandates BS 7671 for installations with generators operating in parallel with, or as a switched allternative to, the DNO supply (Regulations 22 and 23), in the same way as Regulations 21 and 22 of ESQCR do for the rest of the UK.
    Generators includes Solar PV and Battery Storage.
    Yes, Cyprus too in the EU, as well as a number of countries in the Middle East.
