Use of Schuko sockets in a UK home only for a HiFi system
Hello everyone,
This is my first post.
I have a question about using Schuko sockets in a UK domestic home.
But first, a bit of background might help.
I am a Member of the Institution of Mechanical Engineers. I didn't think my people would be very good at answering this question which is why I am here!
In more detail, I would like to use a Schuko socket to which only my hi-fi system would connect. The socket would be connected to a brand-new consumer unit with RCBO’s. There will also be surge protection. All will be done to the latest standards and specifications by a fully qualified electrician. The wiring diagram would be based on the one in this link: https://www.russandrews.com/images/pdf/MainsWiringGuide111023.pdf
I will also have a regular UK 3-pin socket. I am a reviewer for a HiFi magazine and want to do the above as the basis of an article on HiFi power supplies.
So back to the question, is there any legal reason (or otherwise) that I can't use the Schuko socket in the UK?
If the answer is “yes I can”, albeit with specific conditions, I'd like to quote that in my article/review. Especially if the Schuko supply sounds better than the UK 3-pin with fuse!
I am looking forward to your response.
Many thanks
Paul
  • I did the same with televisions. They could be had for 10/-, which soon became 50p. The CRTs were faded so the curtains had to be shut, but with luck one lasted for 6 months.
    Makes me think of the time when, part way through a job / house move, my wife and I were living at opposite ends of the country for a while. On a phone call one evening she told me the television had stopped working, so I told her to give it a hard thump on the top. Took a while for her to believe me, but in the end she did, went way for a moment, and came back and told me with great surprise that it had fixed it. She then asked me what to do if that didn't work, and I told her you thump it on the side instead...eventually I'd have to give up and remake all the solder joints on the CRT base.
    I also explained that I knew this from my degree in electronics. What I didn't say that it was nothing to do with the course, it was because of having no money while I was a student, and so we learned this to get our junk shop televisions working!
    Have you ever tried turning a colour CRT TV upside down? It's highly entertaining what it does to the colours (mostly, doesn't work on all, e.g. Sony Trinitrons you could turn upside down). Took me ages to work out why...used to be a good way of winning a pub bet against engineers who thought they knew about TVs.
  • I also explained that I knew this from my degree in electronics.
    ah I can't say that as I never had a degree in electronics ;-)   But I do have one in physics specializing in solid state and EM..
    In a way it is a great shame that for many folk there is an imaginary ' I cant do that' divide between the practical and theoretical. A few hours fixing domestic electronics teaches you a lot that is not on any course, about oxide layers, what happens where fluff and grot build up, and also not to be afraid of any table top fire you that can extinguish without getting out of your seat.
    In reality I reckon 9/10 repairs were just mechanical - needing little more than re-soldering, switch cleaner, and a bit of wash and brush up. Apart from those wirewound resistive droppers to get the series heater voltages to add up to 230V  that used to go open circuit so often I had spare resistors to spot solder across the failed sections.
    Radios and TVs from households with smokers were the ones needing the clean up the most.
    I have boosted the heater volts to up the emission on a failing CRT a bit. It is all a bit bangernomics, as it shortens the life, but if its on the way out anyway so what.
    M.
  • Have you ever tried turning a colour CRT TV upside down? It's highly entertaining what it does to the colours (mostly, doesn't work on all, e.g. Sony Trinitrons you could turn upside down).
    Sounds like "experiments" I did with permanent magnets and colour TV tubes when very young... which was entertaining until I found the effect didn't entirely  go away when the magnet was removed (for which I was in trouble as it was the family TV..) Eventually I found I could degauss the affected bit of the shadowmask with a transformer borrowed from something else.
  • for many folk there is an imaginary ' I cant do that' divide between the practical and theoretical. A few hours fixing domestic electronics teaches you a lot that is not on any course
    I find in particular about design for real world reliability and serviceability - which can be a difficult balancing act: every connection degrades reliability, but adding pluggable connections improves serviceability. My post graduate training was at the BBC in maintaining a mixture of domestic, semi-professional, and professional audio equipment. Really interesting seeing the difference - what moved equipment into the firmly professional sphere was that it was designed to be modular and with really high quality connectors so that it was both reliable and serviceable. Having been through that really makes you think about your own designs carefully. Anyone who describes a Ferrograph tape recorder as "professional" hasn't tried taking one apart..
    We also sometimes struggle in the rail industry explaining to new design engineers how to think about designing equipment that might need to survive of 40-50 years in a pretty nasty environment - again, experience of trying to repair such equipment is a good object lesson. (Actually, a very surprising amount of the sound equipment I designed in the 1980s is also still out there being used, every so often I go on to the various forums to help people keep them going, which is also good for the keeping the soul grounded! Again mostly switch and connection problems, plus of course electrolytic capacitors. Also oddities like rubber sleeving disintegrating.)
    Also I find studying the best domestic equipment design (i.e. taking it apart to see how it works!) can be a good lesson in simplifying design. Back to the TV lab, the flyback circuit of transistor based CRT TVs I always think is an object lesson in how to design an incredibly complicated function using about four simple analogue components....nowadays you can make pretty much any function by throwing processing power at it, the fun of analogue design used to be trying to use as few components as possible!
    At my age! Mine weighs 38 kg.
  • which was entertaining until I found the effect didn't entirely  go away when the magnet was removed (for which I was in trouble as it was the family TV..)
    And we did have a similarly embarrassing incident with a BBC monitor! Which I'd forgotten about until now...actually I think the problem there was that we tried degaussing it while it was upside down...and as you say it was never the same again. So it got pushed far back to the back shelf of the store room...
    The effect (typically all the colours seem to drain downwards) is apparently partly due to the position in the earth's magnetic field, but I found mainly due to the fine calibration magnets typically being on slightly "dangly" supports which of course droop the other way when it's upside down.
  • The threading in this discussion has made it difficult to keep up with new posts Dizzy face
  • But then equally it may have gone just the teeniest tiniest bit off topic anyway! Joy Fun though...
    Too true of many a thread here, unfortunately.. The 'view latest' option only takes you to the very latest reply, so if like me you only call in occasionally and there have been several replies to a thread since the last look, which are scattered though the thread as people 'reply' to different replies, you can only find them by reading through the entire thing - which is often impractical. Many a time I'm convinced I've seen an interesting reply for the first time even though it's apparently been there for several days. The 'tree structure' doesn't even work properly anyway, since it seems to prune things to two levels - so replies to replies to replies get listed under the 1st reply, rather than under the one you're replying to - making the contortions less worthwhile anyway.
    I can only imagine that those that designed the current scheme either only read historical threads when they're complete (which the structure of who replies to what is somewhat useful) or like teenagers who seem to have everything on their phone with an alert whenever anything is added, seem addicted to reading every reply within seconds of it being added. For the likes of me who only call in a few times a day, when time permits, the old software that listed everything in simple linear chronological order with (IIRC) unread replies emboldened, worked much better.
  • so if like me you only call in occasionally
