Use of Schuko sockets in a UK home only for a HiFi system
Hello everyone,
This is my first post.
I have a question about using Schuko sockets in a UK domestic home.
But first, a bit of background might help.
I am a Member of the Institution of Mechanical Engineers. I didn't think my people would be very good at answering this question which is why I am here!
In more detail, I would like to use a Schuko socket to which only my hi-fi system would connect. The socket would be connected to a brand-new consumer unit with RCBO’s. There will also be surge protection. All will be done to the latest standards and specifications by a fully qualified electrician. The wiring diagram would be based on the one in this link: https://www.russandrews.com/images/pdf/MainsWiringGuide111023.pdf
I will also have a regular UK 3-pin socket. I am a reviewer for a HiFi magazine and want to do the above as the basis of an article on HiFi power supplies.
So back to the question, is there any legal reason (or otherwise) that I can't use the Schuko socket in the UK?
If the answer is “yes I can”, albeit with specific conditions, I'd like to quote that in my article/review. Especially if the Schuko supply sounds better than the UK 3-pin with fuse!
I am looking forward to your response.
Many thanks
Paul
  • 'call in' in this context means "read the fora"
    'Occasionally' clearly means different things depending on your time frame,
    Mke
  • As opposed to "regularly".
    .well, as in not continuously or even so regularly that I can keep up with each reply in real time (which is what the 'view latest' link seems to presume).
    And yes, regular and occasional can mean different things in different situations. Like the landlord who was asked whether stranger in his bar was a regular - 'well yes, I suppose so he said, he comes in once a year on his wife's birthday, rain or shine, and has a small sherry. I guess you can't get more regular than that'.
  • I totally agree. It's been pointed out time and again, so there is clearly no intention do anything about it.
    Edit: Even this reply makes no sense where it has been placed. Looks as though I am agreeing to something different.
  • he comes in once a year
    Just as I go to church regularly at Christmas and Easter.
    Indeed, but quoting makes things clearer.
  • Indeed, but quoting makes things clearer
    Agreed, I did consider that after posting. Out of practice I suppose.
  • provided it has shutters
    Thanks. Well noted.
    If the socket does not have shutters, would this retrofit be acceptable...
    https://www.amazon.co.uk/European-Protector-Mechanism-Adhesive-Children/dp/B0816ZBB9P?th=1
  • Note that reduces the depth to which the pins can be inserted, at full current (16A ) I'd be a bit twitchy but not I suspect in your application.  I suspect the intention of BS7671 is for designs with built in shutters rather than retrofit, but the mitigation of the (very small) risk is the same.
  • If the socket does not have shutters,
    There shouldn't be any problem obtaining one with shutters - they've been a requirement on most parts of the continent for a long time now. Even UK sourced ones usually come with shutters - e.g. https://uk.rs-online.com/web/p/plug-sockets/2676491
  • There are plenty made and on sale without shutters though Germany has them as compulsory in Kindergartens and Schools, large parts of Shuko land (blue on this map) have no such requirement.
    Note that in much of the former East it is not really Schuko as we know it - the layout is the same but the pins are thinner,
