disturbed earth bonding
Dear Engineers
Apologies for lowering the standard of discussion here with my first and probably only question. I had some work done to my mains stopvalve recently. In the cause of this the plumber needed to remove and then reinstate the green and yellow cable. I now noticed that it is not very tightly fastened into the clamp - see photo, and easily wobbles. Also the warning label has disappeared.
My question is: It looks easy to fix and to get a new label. Happy to have a go myself. But is there more to it? Does it need testing, perhaps? In other words: is this for householder or for electrician to remedy.
Many thanks in advance if you can help.
Anna
  • Andy thank you. Practicing is a good idea. then I get a better idea if I can do it for real.
  • This video shows one way of doing it.
    Personally I don't really like that sort of  crimping pliers, and would prefer either ratchet crimps, or the bare wire looped under the screw directly,  without the ring lug. However, the section  showing how the clamp goes together is good, if a bit long winded.
    (and you don't need a purple spanner either, the lock nut can be tweaked with pliers.)
    Edit, or the definitive, if rather school masterly,  "JW"   video - which had I seen if first might have been the only link.
  • Part P (of The Building Regulations) says very little and nothing about any prohibition or notification.
    What you have "clipped out" is not the whole implementation of "Part P", though, is it?
    When Part P was implemented, there was a specific requirement to notify (Regulation 12 of the Building Regulations) of the work in Schedule 1 to the Regulations, unless exempt under 12(6A) of, or Schedule 4 to, the Regulations.
    The OP simply asked whether this was for the householder or an electrician ... I tried to answer that keeping it as simple as possible (in retrospect was that  a mistake?)
    This is the bit of "Part P" that I believe you have omitted:
    Still, I'm an advocate on being clear about things.
  • Thank you again Mike; those videos are really good to watch
  • Ask a qualified electrician. Just as one would seek professional dental care for a decaying tooth rather than attempting a DIY extraction. I believe  safeguarding the integrity of our profession is essential.
    The following poem, by Hilaire Belloc, was published after with the first Edition of what came to be known as the 'Wiring Regulations" in 1882 (then titled 'Society of Telegraph Engineers and of Electricians Rules and Regulations for the Prevention of Fire Risks Arising from Electric Lighting) when it first appeared in the Journal of the Society of Telegraph Engineers and of Electricians (Vol 11 1882):
    Lord Finchley tried to mend the Electric Light
    Himself. It struck him dead: And serve him right!
    For 'tis the duty of the wealthy man
    To give employment to the artisan
    Some things haven't changed much since the 1st Edition. For example:
    • Of the 4 pages, there is half a page dedicated to the "great and the good" who put together the first Edition. Luckily this has shrunk to 2 pages of about 600.
    • The 1st Edition was publicly criticised by electricians, one periodical article running into two pages of detailed comment on the 4-page "rules" Fearful
      Now such criticism appears in on-line Forums and Social Media. (The latest DPC for Amendment 3:2024, which is effectively a single Regulation and two Definitions, received a large number of formal comments and heaps of discussion on social media).
  • It's not the only standard to have "poetry" in it. The following is from the C++ Standard, ISO 14882:2003 (and is still present in the current edition):
    "When writing a specialisation, be careful about its location; or to make it compile will be such a trial as to kindle its self-immolation".
    Though that's a Limerick, so not really poetry...
    I was mistaken (and have edited toe previous reply) ... it was not published with the 1st Edition, but some years later in 1898.
    Hilaire Belloc wasn't born until 1870, which means he'd have been 12 years old in 1882
  • Grinning
