Apprentice (Young Person) Training safe working voltages
Is there any specific guidance, code of practice or legislation which determines a safe working voltage for apprentices in a training facility (school)? Other than EAWR Reg 16, which states people require technical knowledge or experience, or under such a degree of supervision as may be appropriate to avoid danger. HSE INDG354 mentions as a rough guide that the use of voltages exceeding 50v ac or 120v ripple-free dc are hazardous in certain conditions.
So as an example, a first year apprentice wouldn't be expected to work on or near 240v ac (they are unaware of the risk). Only when they have gained suitable knowledge and experience through adequate training, would the risk be increased from a safe voltage. I'm not suggest apprentices can't train with 240v ac, but I would expect them to start on the theory and understand basic electrical principles before they are put at that risk. The start of an apprenticeship doesn't warrant a danger voltage to prove basic principles and electrical testing/theory.
All thoughts and opinions are appreciated.
RJ
  • There is no difference, as far as I know, either in the letter of electrical regulation, or in the biology of what happens during a shock, between an unskilled adult of any age, and an unskilled trainee doing an exercise at college or working alongside experienced hands as part of their apprenticeship or whatever.
    As such the same health and safety regime should apply and the risk assessment of what folk are able to do at various levels in training needs to be performed by someone with practical as well as theoretical experience.
    There is guidance out there that colleges and so on work to, but  I don't have up to date copy- probably others here do - Lyle may well for example.
    Ideally no one would ever touch live metal with bare skin, inexperienced or otherwise, though how hard we should make that to happen accidentally does, of course vary with experience. In practice, some kit has to be configured with the lid open, so one or more of the layers of safety that would protect unskilled persons is then compromised, and folk like DNO jointing teams routinely work on live cables, relying heavily on procedure and the right tools to make the job safe - but of course they also avoid live metal to bare skin contact, just in a different way.
    Equally consider the normal lamp holder - clearly not finger proof, but apart from in Tom and Jerry cartoons and The Addams family, it is very rare that anyone actually sticks their fingers in one, and they are used by unskilled persons.
    As per above, there should always be defence in depth, i.e. multiple things must go wrong to reach a truly dangerous situation. For example training benches are also fed by RCD, and be on a dry non-conductive floor,  even though the users will have been taught the principles of isolation, and should only be touching terminals that are dead, and verifying they are before they do.
    In terms of the biology, its not the voltage per-se that kills but also how long it is present for, and how much current is flows or is available during that time, and references to voltages should be tempered by an understanding of the type of contact - a large area of sweaty or damged skin is a much better contact than a finger tip so more dangerous, while a gloved hand is better than a bare one.
    It is for this reason that there is gravel on the ground at substations - water drains, so there will be no puddles, and the contact between stones and foot is small pointy areas ,and the discomfort of feet on gravel means that even the most gung-ho folk are most unlikely to be wearing anything less than boots with a proper sole.
    A shock hand to hand or hand to opposite foot crosses the bit with heart and lungs in and so is  the most  serious, and currents that are short duration compared to half a heartbeat period can be higher with reducing duration for the same risk of fatality - so  an electric fence is 10,000V but for a few  hundred microseconds, but an RCD must remove the mains from a person within 0.4 seconds at 230V, and rather longer at 110V.
    So non conductive footwear, and ADS speeds are set this way ;-)
    Its a bit of a ramble, but let's see what others say.
    of course when the trainees come to test RCD breaking times, an RCD protected bench may need something else to allow the test to not cut everything.
  • Mike:
    The best piece of safety advice I ever got was---  don't wear any metal on your body- like rings or tie clips !
    Peter Brooks
    Palm Bay
  • Is there any specific guidance, code of practice or legislation which determines a safe working voltage for apprentices in a training facility (school)?
    I'd add it might depend on the nature of the activity ... e.g. wiring a plug that is then inspected/tested by a tutor before being plugged by the student to complete the demonstration isn't quite the same as live working on bare live conductors (e.g. proving dead) - even though the same voltage is nominally involved in both. So maybe it's more a case of choosing the activity rather than the voltage.
  • don't wear any metal on your body- like rings
    Was that electrical safety advice, or personal relationships advice?
  • If it's in a training facility or classroom environment, this standard should be applied: BS 4163:2021+A1:2022 Health and safety for design and technology in schools and similar establishments – Code of practice
  • My policy for my students at college was no metalic jewelry, or if it cannot be removed for cultural or religious reasons it had to be covered with tape. Also rubber soled shoes or boots in good repair.
  • Worth also remembering that the EAWR is in terms of danger rather than simple electric shock, and the term incorporates hazards associated with heat, arcs and sparks, etc.
    Controlling voltage alone doesn't help with danger in general, so I would say that employers and training organizations ought to consider the risks in the round to comply with legislation.
    Also worth remembering that no-one should be "working live" (different to "testing live" with suitable equipment) so initially at least, the important things are the safe isolation approach, and adequate supervision to make sure safe isolation is being effectively done before work starts ... irrespective of voltage involved where currents can provide danger as defined in the legislation, which may include ELV (including SELV and PELV) systems as well as LV systems, particularly where high current (anything with short-circuit currents above 1-2 A or so) sources such as batteries are involved
  • That was for electrical safety, which also included RF induction heating
    So far no one has mentioned suitable eye protection.
    Working around rotating machinery can cause significant problems if guards are missing or never considered during the design phase.
    Tight fitting clothing (like school ties around the neck) should also be removed.
    Peter Brooks
    Palm Bay FL USA
  • Someone mentioned PPE.
    I assume that the college would have carried out a Risk Assesment for the activities in the college workshop? That would have determined what the risks are and if they cannot be eliminated measures would be put in place to mitigate the risks. A RAMS developed and comminicated. PPE is a last resort if the risk cannot be eliminated. So for working at eye level eye protection will always be required. For handling conduit suitable gloves. Striking anything with a hammer calls for a minimum of eye protection and probaly gloves.
    I would say for the Level 3 students at least once a week to be made to wear in the workshop all 5 pieces of PPE to get them used and comfortable wearing  as they will be required to do this on building sites. No shorts, no radios and no wearing of headphones or ear buds as they are not allowed to do this on most sites. They will moan and groan but this is what you have to do on site so just get on with it as it is part of your education.
    JP
  • school ties around the neck
    I hit the emergency stop in the metalwork room at school when another kid was dragged into the grinder by his tie.
    We had been told to remove our ties, but he just tucked it behind his apron and it fell out, I saw the grinder dragging him in at the same time as the teacher did and we both hit wall mounted emergency stops, he escaped without injury but the teacher had to cut his tie off.
    I can’t remember connecting anything to an electric supply at college until we did motor control wiring as part of the C&G 2360 part 2, an apprentice would have been in the third year of college and working by then, and over the age of eighteen so considered an adult.
    Live testing was not part of the C&G 2360, so an apprentice would have been in their fourth year, twenty years old, before being able to do the inspection and testing course, and live test loop impedances and RCDs.
