Which stair lights would be best?
Hi
I am not sure I am posting in the correct place! I was looking for a forum that could advise on these 2 things:
1) Our Edinburgh tenement stair lights (5 lights with 2 florescent bulbs each) have been upgraded to 5 LED ones instead. There was an option to keep the original florescent lights but we chose to upgrade, while getting issue (2) sorted below. However the new LED lights are VERY bright and causing a lot of glare (very uncomfortable to look at). Would be better switching back to the older florescent ones or is there more appropriate kind of light and/or diffuser which would be more suited to stair lights?
2) 4 of the lights are on a timer (other 1 is on permanently) which switches on in the evening and off again in the morning. The timer, I believe, is 50 years and looks to be some kind of electrical/mechanical rotary switch which you can adjust to alter the switching on time. However I don't think we can alter the LENGTH of time it stays on, just the start time for a specific period (about 14 hours just now I think). The problem is - there is not enough ON time to avoid periods of darkness in the winter (dark for about 2 hours in January). My question is - can we fix this? It has not been a problem in over 20 years but somehow it is a problem now. We have been advised to get a digital timer but can we keep the original one, if its fixable?
Any advice would be gratefully received.
Thank you
Iain Millar
  • Can you post a photo of the timer ? There are many types and the correct action will vary.
    I'd not endorse a return to florry lights now, though maybe hold out on changing any more for the moment. In time the spare tubes will get very hard to obtain, and the fitting will need changing eventually anyway.
    Watt for watt leds are a lot brighter, and in the cheaper ones the colour rendering can be a bit odd, so you find that you can be both dazzled and yet unable to see fine detail in coloured objects at the same time.
    Looking at diffuser (or reflector) to throw the light around a bit may be an effective option, being point sources, strips of LEDs can give a sort of hard shadow 'soot and white' wash look to things.
    There are literally hundreds of designs to choose from, and it is worth looking at the data in terms of radiation patterns and shapes , and ideally looking at samples of the fittings prior to splashing out. It reads rather as if that horse has somewhat bolted in your case.
    Some light fittings can have a diffuser retrofitted, but that is a conversation to have  with the suppliers.
  • Thanks for the very helpful reply that I received today. I have now attached two photos of the timer.
  • I can't see the pictures I'm afraid, but from what you said, I wonder if it's one of the old self adjusting timeclocks that mechanically adjusted the 'on times' according to the time of year (I recall them being used in street light when I was very young, before the advent of photocells). Proper works of art in brass they were. If so it sounds very much like someone's been messing with it and has just last left it set at the wrong time of year - if so it should be a simple matter to correct it.
  • With regards to 1, quite a few LED light fittings are adjustable for light level and colour. Might be worth looking at which ones were installed and whether they can be adjusted.
  • that great-many thanks Andy, really appreciate it
  • thank you very much, i'll look into the new lights. best wishes, Iain
  • JW has done a video about the kind of timers I remember: https://www.youtube.com/watch?v=1q15QFMi6dY - the one I remember wasn't quite like those - as I recall it had a plastic casing and red on/off knob more like the first but the mechanism was definitely the self-adjusting kind very similar to the one starting at around 8:55 in the video.
  • Is there any way you could apply tape to the most glaring bits of the lights, or mask them and paint them?
  • Sorry for not replying sooner Simon- I'm hoping we don't have to that but good to know. Thanks, I appreciate it.
  • If it is an Astronomical time clock (the type Andy describes that automatically adjusts the ON  & OFF times to track sunrise & sunset) its worth pointing out that these need to be set for GMT and should not be changed to BST in the spring. The mechanism automatically compensates for the lengthening & shortening of the day.
