Struggling with insulated consumer units and information on power dissipation
I am quoting for a new consumer unit to go in to  a domestic garage. Supplies 3 circuits in the garage and a couple of circuits to other outbuildings.
Especially with the recent guidance on metallic consumer units outside I have been leaning towards using a plastic consumer unit, then comes the challenge.
I don't think anyone still builds populated consumer units for more than 4 ways. So then I look at building my own and power dissipation, very little information available from what I can see, the only company providing data is MCG at 1a very low 11W.
The best I can find is that some enclosures state then are ok for say 63A, no idea what the assumed heat dissipation is. Also heat a dead end when looking for heat dissipation from RCBO's, I remember in the past seeing 12 to 15w at full load. So I seam to be left with a choice of putting a metal board in and hope it doesn't suffer from condensation, or puta plastic one in and hope it doesn't over heat. I could also put a metal board in a plastic enclosure, a bit less risk with heat.
I could probably just use any plastic din rail enclosure and not have an issues, but frustrating this is so difficult.
Thoughts?
  • I agree much better to stick with what BS7671 states and use metal CU. The product below would be ideal and will not rust.
    FuseBox F100GRA Garage Consumer Unit - The FuseBox F100GRA Garage Consumer Unit is a popular choice for residential garages due to its durability, compact design, and excellent safety features.
    Key features of this consumer unit include:
    • Design - The FuseBox F100GRA is a metal consumer unit constructed from high-quality steel, ensuring durability and protection against impact and environmental conditions. It is designed to accommodate various electrical circuits with up to ten usable ways, providing flexibility for connecting multiple devices and appliances.
  • BS 7671 does not say you must use a metal CU in an outbuilding or garage - it says just lists it as one possible fire reduction measure for installations within domestic buildings. I agree that the practical effect is that mostly folk fit steel everywhere willy nilly, and that is what most wholesalers stock - but there are plenty of places where the environment makes that unwise. its not that many decades ago we were ripping out badly corroded metal switchgear where the earthing had rotted off in church basements and farmyard out-buildings to replace it with the then more modern  non-rusting plastic alternative. A lot of the problem is the choice of which plastics, and if suitable fire retardant has been added.  In many ways, CU makers have been quite sloppy. After all, meters and service heads are nearly all insulating by design these days, and in many DNO regions if you report a cast iron service head, they will come and change it (very carefully if there is an asbestos risk) for a new one.
    I can't see the detail of the original posters situation of course, but the world is not as simple as 'steel good - plastic bad' in all cases.
  • lThose Blakley units are really very good & solid, and optionally available in stainless steel as well as with rain covers on request. (https://www.blakley.co.uk/products/permanent-distribution/ip66-mcb-distribution-boards/distribution-boards-ip66-125a-spn/14w-125a-ip66-spn-mcb-distribution-board/)
    However most steel CUs are not full seam welded, phosphated and epoxy coated like that. A light dusting of powder coat is more likely, so  do not expect the same life from a wylex.
    for temporary outdoor power, personally I find rubberbox very good, but not a cheap option either ;-)
  • Dear Map 1,
    Thank you for your input on the selection of consumer units for garage installations. I appreciate your willingness to contribute to this discussion.
    While it is true that BS 7671 does not mandate the use of metal consumer units in outbuildings or garages, it is important to note that the regulation lists it as one possible fire reduction measure for installations within domestic buildings. As a qualified JIB technician, I believe in following the guidelines set forth in BS 7671, as they have been established for valid reasons, primarily to enhance safety and reduce fire risks.
    Key Points to Consider:
    • Durability and Environment Suitability: The FuseBox F100GRA Garage Consumer Unit, constructed from high-quality steel, is an excellent choice for residential garages due to its durability and ability to withstand various environmental conditions. This makes it an ideal solution for external environments like garages.
    • Regulation Adherence: Although adherence to BS 7671 is not legally required in all situations, it is highly advisable to follow these guidelines to ensure safety and compliance. Ignoring these recommendations could lead to serious consequences, including fire hazards. In the unfortunate event of a fire or fatality, not adhering to these standards may result in legal repercussions, and a judge is unlikely to look favorably on the use of substandard materials.
    • Historical Context and Practical Experience: There have been numerous incidents where the use of plastic consumer units has led to significant fire risks. This is a key reason why the regulation encourages the use of metal consumer units. Additionally, the historical challenges with metal switchgear in certain environments underscore the need for selecting appropriate materials based on the specific conditions of the installation site.
    • Fire Retardant Materials: It is crucial to consider the type of plastic used and whether it includes suitable fire retardants. Consumer unit manufacturers have sometimes been lax in this regard, leading to suboptimal products. Therefore, selecting a metal consumer unit like the FuseBox F100GRA, which meets BS 7671 standards, is a prudent and safe choice.
    In summary, while it is not mandatory to use a metal consumer unit in every situation, it is a highly recommended practice to enhance safety and compliance with regulations. The FuseBox F100GRA is designed to meet these needs effectively, providing a reliable and durable solution for garage environments.
    Thank you for considering my perspective. I hope this information is helpful, and I am open to further discussion on this matter.
    Best regards, Gary Qualified JIB Technician
  • the guidelines set forth in BS 7671
    I thought I knew BS 7671 quite well, but I don't recall anything like those words appearing in it...
  • Dear Andy,
    Thank you for your response and for highlighting your perspective on BS 7671. I appreciate your diligence in understanding the regulations thoroughly.
    The phrase "guidelines set forth in BS 7671" is intended to reference the general principles and recommendations provided within BS 7671 for electrical installations, including those in domestic buildings. While the specific wording may not be verbatim from the document, the essence of BS 7671 is to promote safety and minimize fire risks through established practices, one of which is the recommendation for metal consumer units as a fire reduction measure.
    Regulation Adherence: According to BS 7671: 2018 Amendment 3 Regulation 421.1.201, it is recommended to use metal consumer units in domestic premises to reduce fire risks. Although adherence to BS 7671 is not legally required in all situations, it is highly advisable to follow these guidelines to ensure safety and compliance. Ignoring these recommendations could lead to serious consequences, including fire hazards. In the unfortunate event of a fire or fatality, not adhering to these standards may result in legal repercussions, and a judge is unlikely to look favorably on the use of substandard materials
  • "POA" is never a good sign.
  • It should perhaps be interpreted as 'if you need to ask for an estimate, you probably can't justify the cost on that project'
    Ryfield has a similar pricing structure. The other giveaway is if the lead time after order is more than a few days == we have not got stock, we build one when you  order,,,,
    Some of the stuff I've been working on recently has seen components quoted at  26 and 52 week delivery - 'supply chain issues' -really? for a lot of this stuff I could make one in my garage in that time,
  • I don't think anyone's suggesting not complying with BS 7671, but the "guidelines" you quote seem tell only part of the story. For instance, 421.1.201 only applies to Domestic (household) situations - which most guidance seems to suggest doesn't include detached garages. While fires originating in CUs are a recognised problem, a designer needs to consider many other aspects of safety and suitability for location as well.  For example condensation forming inside a CU may well have an adverse effect on delicate components such as RCBOs, failure of which may pose greater risk to human life (especially of the garage is TT'd). The vast majority of fabricated steel CU enclosures (including the F100GRA you mention) seem to have no seals to exclude damp air that can lead to condensation - whereas many plastic ones do. You might even consider something like the FuseBox A65 series(e.g. FuseBox A65GRAWH) (although I can't tell from the web page whether it's moulded plastic or die cast metal).
  • Dear Andy,
    Thank you for your response and for highlighting your perspective on BS 7671 and the considerations for consumer units in garages.
    I appreciate your point about the specific application of Regulation 421.1.201 to domestic (household) situations, which might not explicitly include detached garages. I also acknowledge that condensation inside a consumer unit (CU) can pose a risk to delicate components such as RCBOs, potentially leading to greater risks to human life, especially in a TT system.
    To address these concerns, it's essential to consider the specific environmental conditions of each installation site. While metal consumer units, like the FuseBox F100GRA, offer durability and fire reduction benefits, it is crucial to ensure they are suitable for the given environment.
    Potential Solutions:
    1. Sealing and Insulation: Consider applying additional seals or insulation to the metal CU to mitigate the risk of condensation. This could help protect the internal components from damp air.
    2. Alternatives: Explore alternative consumer units that are designed to withstand damp environments. For instance, the FuseBox A65 series might be a viable option, though it's essential to confirm whether it is molded plastic or die-cast metal.
    3. Environmental Assessment: Conduct a thorough assessment of the garage environment to determine the best-suited materials for the CU. In some cases, a high-quality plastic CU with appropriate fire retardants might be a better choice.
    Ultimately, the goal is to ensure safety and compliance with BS 7671 while considering the specific conditions of each installation site.
