Retro marking cables in the German electrical Installation industry
Hi
I am working as a project engineer in Germany and are we installing new distribution switch gear due to age.  Currently the earthing arrangement is TNC but will be changed to TNS due to compliance.  The problem then being that all equipment is installed as a 4 wire system, with a combined earth and neutral. The Cable colours are generally brown,black,blue being the phase wires and green/yellow is the combined N/PE.
 To overcome the earthing issue we will install separate protective conductors from the main earth terminal, but, I have been informed that the green/yellow cannot be marked for any other purpose other than earth.  This seems madness as this encompasses the whole site and will therefore require for the whole installation to be rewired.  As you will all know that this is not sensible or affordable.
so if anyone has answers to this question it would be greatly appreciated
  • Oh indeed. Something like this should be taught in lesson one..
    “When I choose a cable colour,’ Humpty Dumpty said in rather a scornful tone, ‘it means just what I choose it to mean — neither more nor less.’
    ’The question is,’ said Alice, ‘whether you should make the same colours mean so many different things.’
    With apologies to Lewis Carroll and "Alice through the Looking Glass" (electrical edition).
    Having 'identified' the correct wire, now check with a meter..
  • but the installation is already a little odd in  having a blue third phase - with that, I'd have expected to see an old German style red earth in that case
    The OP's top thread said "brown,black,blue being the phase wires and green/yellow" - which almost sounds like they're used fairly modern (harmonized) 4-core cables - I think our 4-coure flexes were brown/black/blue/gy before we got grey introduced with the latest round of harmonization at which point I think they turned brown/black/grey/g-y.
  • but its not actually any of the VDE recognized colour schemes ;-)
    But probably correct.
    I have always been very wary of colours on the continent, especially red, and not very trusting of them here either..
    Worst ever was a colleagues  Greek wired 3 phase pump. Brown phase 1, blue phase 2, green yellow phase 3.... can we guess what happened here !
    M.
