Doubling over terminations
Hi I may have posted a similar question before so apologies if I’m repeating myself. I was working with another electrician the other day second fixing a house and noticed that he doubled over the cpc’s when connecting socket outlets. Not the line or neutral however. This was using 2.5 t&e with 1.5mm cpc. I personally have experimented with different termination techniques over the years and discovered that there can be no’one rule fits all’ technique as terminal types differ greatly. However on socket outlets the design across the board seems to be a roughly square terminal with rounded sides. I find that 2.5 sit quite well side by side and the screw doesn’t push down on top of them as such but pushes them out to opposite sides of the terminal where they are trapped in the corner and achieves a decent enough connection in my opinion. With the cpc being 1.5 mm2 ,using the same technique works ok but as it is smaller there is less copper for the screw to make contact with and the conductor may attempt to slip up the side of the screw ( however the design of Click sockets that I use looks like that couldn’t happen).
When terminating anything I normally double over a single conductor if there is only one going in the terminal if the terminal allows it but wouldn’t double over if two or more conductors are going in.
With the socket outlets, there is still a lot of empty space in the cpc terminal with two conductors put in straight and with the ‘fill the hole with copper’ voice ringing in my ears, the temptation would be to double over the two 1.5mm2 cpc’s but I don’t like the idea of a single screw trying to equally clamp on what is now essentially 4 x 1.5mm2 cpc’s. When experimenting with straight or doubled over terminations, both pass the pull test ok.
I know that this and similar topics have been discussed to death over the years but keen to hear others opinions. When watching various electricians social media videos, it’s clear that both methods are being used so I’m guessing that it’s down to what way you were taught / personal preference / speed. Who knows!
  • I must admit I'm in the 'look at it and see' and then if in doubt fill the terminal camp - the problem actually is that nearly every manufacturer has their own house style of terminals with varying degrees of gap beside screws or clamps, or the graunch factor of how much the terminals chew up the ends of the cable. Rather like the ferrules on stranded cable question, there will be cases where it is essential, and cases where its not sensible. Certainly if there is too much hole and any credible risk of it falling out or missing the contact, then folding to fill the terminal with copper is my preference, or if a flat plate clamp would otherwise come down crooked, and bind before making a good contact.
    There is a weakly related example with military crimps in the circular connectors, the instructions require you to add filler strands when terminating a stranded wire that is a rattling fit to the pin, so the crimping pressure is retained. This is considered preferable to solder, which is the other permitted alternative, if the vibration spec is lower.
    Back to mains connectors - What you don't want is to be too dogmatic about it in cases where it won't work. If it is a nice low resistance, and mechanically sound, it's likely to be OK.
  • +1 for it all depends. Years ago, working with solid core T&E I used to like to double over when putting two wires into a terminal - with a little care they could be arranged so the screw would bite into the turned over part and in almost a wedge fashion push the main conductor undistorted firmly to the sides of the terminal. That was in the old days when terminals were real terminals, solid brass with round holes and brass screws that never snapped. These days I seem to work more with stranded cores - which don't double over as nicely, but the strands can be moved about to better fill non-round terminals. So whatever works best for the particular wire and particular terminal.
  • To my mind, the risk of doubling is that the bend may damage the conductor.
    I have experienced lower quality sockets where the CPC was simply not gripped, so R2 was excessive.
    With a ring or middle of a spur, there is always the option of twisting the two CPCs around each other.
    Frankly, the modern solution is screwless terminals.
