Amendment 4 (2026) to BS 7671:2018 IET Wiring Regulations.
I assume it’s now less than a year until the 4th Amendment is published, here on the IET website it says:
Amendment 4 is expected to be published in 2026, until that time electrical installers need to have a copy of Amendment 2 (2022) - the ‘brown book’ and Amendment 3 (2024) (free PDF bolt-on) to be up to date.
https://electrical.theiet.org/bs-7671/updates-to-18th-edition/
So, it is time to start planning ahead.
My first question is it a new book? There seems to be a lot of additional information and possibly changes as well.
My second question is, will there be an update qualification requiring a day on more in a training centre with an exam to be taken?
I have a couple of IET book markers somewhere with some information about this printed on them, but I’m not sure where they are at this moment.
There is a third question, which is when the 19th Edition is being published, which presumably will require new books and an exam, but I assume that won’t be published for at least two years?
  • I have found the book markers, which were printed quite some time ago and have a very non-committal “Likely 2026” on them.
  • My second question is, will there be an update qualification requiring a day on more in a training centre with an exam to be taken?
    Just out of interest, do you think there was any measurable benefit in dragging the hoi polloi of the electrical installation industry through three days training on how to use an index when the 18th Edition was introduced? In my experience, few have any recall of the most fundamental issues a couple of days after proudly waving their certificates, won with a mere 60% pass mark.
  • I seem to recall it was discussed here a few years ago that there can only be 3 amendments, after that a new edition has to be written. Or maybe that has changed since we left the EU.
    I know that much, Amendment 4 should have been Amendment 3, but an additional amendment was required because of the problems with unidirectional RCBOs being installed upfront of solar and battery inverters, and their circuit boards burning out when the test button was pressed whilst the inverter was running.
    So what should have been Amendment 3 has become Amendment 4.
  • So, it is time to start planning ahead.
    There is no official information at the moment. However, lots of changes usually means the best approach is an updated 'book'.
    We don't know the answer to that question yet.
  • Thank you.
  • There is no official information at the moment. However, lots of changes usually means the best approach is an updated 'book'.
    Like a toddler weaned from its dummy, it took a long time, but I am now a convert to the electronic version. My brown book is battered and abused but I rarely have need of it now.
    However, whether the lumberjack squads will be out felling forests for the next iteration remains to be seen. I imagine a large part of hard copy demand is driven by the current exam format so unless a new greener method of assessment can be devised, I guess axes will continue to be sharpened.
  • I guess axes will continue to be sharpened
    Unless we break with tradition and instead of a big red book, we go for a Green one.
    I would perhaps also add, that the DPC for the next Amendment was "the whole book"
    With the information available here: https://electrical.theiet.org/bs-7671/updates-to-18th-edition/ well, I guess that's all the publicly-available information, so our industry rumour mill can eat all this information and provide an answer.
  • Unless we break with tradition
    Which 'tradition' ?
    If you look back carefully, we'd first have to ignore 18th Edition, and prior to that you might be able to discern a 'pattern' for 17th Ed against 16th Ed against 15th Ed.
    BUT
    Even that is 'broken' for those who want to be very pedantic, because the 16th Ed of the IEE Wiring Regulations, published in 1991, was published with both a red cover (paperback) and a dark blue cover (hard back)
    When you write down the cover colours and try to order them, there is no pattern at all really. Red appears as a cover colour for the first version in each "edition" most often ... but it's not a "rule" ... and prior to 8th Edition, there is no cover; as far as I know, they were all white "pamphlets".
