Amendment 4 (2026) to BS 7671:2018 IET Wiring Regulations.
I assume it’s now less than a year until the 4th Amendment is published, here on the IET website it says:
Amendment 4 is expected to be published in 2026, until that time electrical installers need to have a copy of Amendment 2 (2022) - the ‘brown book’ and Amendment 3 (2024) (free PDF bolt-on) to be up to date.
https://electrical.theiet.org/bs-7671/updates-to-18th-edition/
So, it is time to start planning ahead.
My first question is it a new book? There seems to be a lot of additional information and possibly changes as well.
My second question is, will there be an update qualification requiring a day on more in a training centre with an exam to be taken?
I have a couple of IET book markers somewhere with some information about this printed on them, but I’m not sure where they are at this moment.
There is a third question, which is when the 19th Edition is being published, which presumably will require new books and an exam, but I assume that won’t be published for at least two years?
  • e.g. Brown/Black/Grey - brown is L, Grey is oversleeved blue as N, so Black is IC
    Agreed, save that since neutral used to be black, I might over-sleeve that in blue.
    That assumes that a cable can be drawn in from a common point to each alarm. If not, the nearest ceiling mounted luminaire will do and the alarms can be connected by magic (i.e. wirelessly).
    If a room has no ceiling mounted luminaire, it becomes more problematic.
  • Agreed, save that since neutral used to be black, I might over-sleeve that in blue.
    And you might interpret the requirement of BS 5839-6 in a different way, as my previous post, ruling out BN, BK, GY, BU, RD, WH for all installations and additionally YE for installations with "mixed" colours. Assuming we don't want to use GN (to avoid confusion with protective conductor), and PK also being out because it's FE, this then leaves: VT, OG, TQ to choose from.
    So, at the next iteration of BS 5839-6, a choice from those three colours, Violet (VT), Orange (OG) or Turquoise (TQ) can be made in what is currently Clause 16.4, and we have a standard approach. Easy.
  • So, at the next iteration of BS 5839-6, a choice from those three colours, Violet (VT), Orange (OG) or Turquoise (TQ) can be made in what is currently Clause 16.4, and we have a standard approach. Easy.
    Could that also be added to the following?
    OG (On Site Guide)
    GN3 (Guidance Note 3: Inspection & Testing)
    GN4 (Guidance Note 4: Protection Against Fire)
    Will the FIA (Fire Industry Association) be made aware of this recommendation?
    OG (On Site Guide)
    Probably not in advance of BS 5839-6 including the provision.
    In any case, wouldn't the IET Electrician's Guide to Fire Detection and Fire Alarm Systems be more appropriate? I don't think that OSG, GN3 and GN4 go "inside" fire detection and fire alarm systems to that extent?
    I believe that FIA have representation to the relevant standards committees. Also, consider that public consultation is necessary for British Standard, hence, my recommendation for it to go in BS 5839-6.
    A technical committee is usually assembled to consider the IET Electrician's Guide to Fire Detection and Fire Alarm Systems, and I think this also goes out for public consultation if memory serves correctly.
  • Probably not in advance of BS 5839-6 including the provision.
    Ok so BS 5839-6 is the start of the journey and you are on point with  IET Electrician's Guide to Fire Detection and Fire Alarm Systems, being included
    I assume the  IET Electrician's Guide to Fire Detection and Fire Alarm Systems, is due for a new revision at some point as the 3rd Edition was released in 2021
  • Have to agree Lyle, so much so that I gave up chasing bits of paper after I did the old 16th and the old 2391. I suspect many others did too.
    I became so fed up that I suffered a massive bout of paralysis by analysis. I got pretty sick of those self-interest-centred grifters who dominate lobby groups telling me that my quaifications and experience counted for nothing unless I had the latest shiny qualification. Eventually the scales were cast from my eyes and I began to see the whole scam for what it really is. At that point I resorted to just buying 'Guide to the xxx Edition of the wiring regulations' instead.
  • I assume the  IET Electrician's Guide to Fire Detection and Fire Alarm Systems, is due for a new revision at some point as the 3rd Edition was released in 2021
    Probably, yes, especially as BS 5839-1:2025 is now available.
    I believe so.
    Anyone can make a suggestion to include a change in a standard ... the relevant committee can be contacted using the "Message committee" button on their page on the standards development web-site. For BS 5839-6, it's this one: https://standardsdevelopment.bsigroup.com/committees/50002208
    BSI advise anyone making suggestions to specifically state the change they would like to see in the standard (what you'd like the words to be changed to). This is also recommended when commenting on drafts for public comment .. see https://standardsdevelopment.bsigroup.com/Home/About
