black cut out fuses
i have come across black cut out fuses that light up my single pole tester, but only on the label.
my 2 pole tester does not light up from label to MET.
is this my single pole tester being over sensitive or should i call 105?
  • On second thoughts, the reluctance may be due to the possibility of (very unlikely) confusion between Mm and mm.
    You would think that the context and a factor of 109 would make it obvious.
    Along similar lines, it seems odd that annual domestic energy consumption is usually given in thousands of kWh rather than MWh.
