Beginner's guide to solar PV
Any recommendations for some simple guidance on solar PV please?
I want to get a better idea of what may (or may not) be feasible at home before I obtain quotes. So not too simple, but I think that the Code of Practice might be too detailed and technical.
  • Thank you, Steve - very reassuring.
  • Maybe it's time to check my LG Chem batteries against the latest recall list. It seems that LG batteries are known for their flammability BatteryFire
  • It feels that the risks from LiFePO4 batteries pale into against the current practice of connecting homes to an almost unlimited supply of immediately highly flammable and potentially explosive gas (orLPG cylinders), routing it through building voids in thin metal pipes with weak on-site made joint and without any means of automatic shut-off. www.independent.co.uk/.../gas-explosions-uk-investigation-safety-b1794742.html
  • Yes the evidence does point to LFP batteries being safer than NMC, but they are still electro-chemical cells, there's still the potential for internal faults to result in off-gassing and release of flammable or hazardous gasses, so in terms of managing any risk, still better to place those batteries outside of the building in a non-confined, well ventilated location where possible,
    There have been some incidents reported involving home LFP installations:
    www.pv-magazine.com/.../
  • There have been some incidents reported involving home LFP installations:
    That was quite a big one for domestic, even if 3-phase.
    All you need is a somewhat demented older person, who turns on the gas stove, but forgets to light it.
  • Luckily, modern gas stoves have flame out detectors. On mine, if you turn the knob and leave it, nothing happens. To light it, I have to press the knob down which overrides the thermocouple and operates the ignitor.
  • I remember this report at the time. Seeing as it's from 2023, it would be nice to see the final report. If this was indeed caused by LiFePo4 chemistry cells, then any issue of gas build up is easily mitigated by requiring the batteries be installed inside a cabinet attached to an external wall with a vent/chimney to the outside.
  • The battery doesn't even have to be abused to fail, there's been incidents in continental Europe where home batteries have developed a in-service fault and failed, starting fires or in some cases explosively, there's been a few incidents reported of lithium ion home batteries  causing significant structural damage.
    It's for this reason I would be very wary about ever locating the battery inside the building.  Installed on an outside wall, any energy release is outside the property and if the battery does start off-gassing, releasing flammable gasses then there's no confinement to allow an explosive atmosphere to form, the gasses naturally disperse.
    www.ess-news.com/.../
    And thinking longer term, I wonder how all of these batteries installed in people's homes are going to be safely managed as they steadily degrade and reach end of life. These are not routinely maintained, tested or inspected. Will they all gently degrade and simply fail in a benign way, or be safely shut down by protection or internal safety measure. Or as the cells, or rather strings of cells, start to degrade will we start to see more batteries failing in a hazardous way.
    I'm glad you posted that link.  I've just crawled into my loft, and sure enough my LG battery pack is one of the ones subject to recall.
    I will have to leave it until this evening when the battery is below 100%, then go back into the loft and hit the breaker on the battery box. The inverter should still work fine without a battery until I find out what LG are going to do.
    That is what PAS 63100 recommends.
    Many lofts are also not good for the thermal conditions (and other environmental conditions such as dust) that can affect the battery ... or inverters, for that matter.
  • Many lofts are also not good for the thermal conditions (and other environmental conditions such as dust) that can affect the battery ... or inverters, for that matter.
    Or access.
    But even if the battery is outdoors, should the inverter not be indoors?
    Situating the battery outdoors is all very well, but it also needs to be accessible for operation, inspection, testing, fault detection, maintenance and repair (132.12(b)).
