HV code 3 number 2
I note that Philip Oakley responded to the original HV code 3. For some reason, I cannot see any responses either on iPad or PC. A tab indicates that there is an error and the moderator is aware. Can someone advise if they can view the post with all responses?
  • Hi Mike
    Check out the threads in our Using EngX forum as that's where we've been moving any posts specifically relating to the issue to. Keeps the Wiring Regs forum on topic Blush
  • Oh, a hidden discussion forum ! Oddly one not shown on the banner on the discussion origin page
    Apart from following the link your  post above, what is the correct way to find or link into it please ?
    (i normally come in via https://engx.theiet.org/f  coz I can remember that, I'm not sure how others get in,  the about page on the wider site does not link to either )
  • Hi Mike
    From the 'Explore' menu at the very top or if you're visiting on a mobile device, it's the three line 'burger' menu at the top. You'll see the 'Using EngX' option in the navigation options which will take you to that area of the EngX community where you'll also find our How to use EngX guidance documentation. Remember that the EngX community is larger than just the discussion forums Wink
  • Thanks for that. Useful to know there is another set of posts there.
    Oddly I get both get 3 lines and the word Explore in the frame header, next to the words IET EngX.
  • If you're viewing on a desktop or laptop Mike then yes you'll see both the three lines and Explore. For the mobile device view though, that reduces to just the three lines 'burger' style menu, unless of course your mobile device's personal preferences are set to display websites in a different resolution/format.
  • Well, laptop and iPad look just the same here, but no "Explore" on the dog and bone.
