Protected corridor lighting cabling compliance
Hi - I'm currently working on a residential project that has a protected corridor. I'm happy with how to deal with the general wiring and compliance, however I have been asked the question regarding the cabling between the luminaire and the driver. How to make this compliant, has anyone else had this issue. Section 422.2 clearly addresses the supply cable requirements but I can't find anything relating to the driver cables. Help most appreciated.
  • Not all suspended ceilings in the UK act as fire barriers. A suspended ceiling only functions as a fire barrier or fire-rated membrane if it is explicitly tested, certified, and installed to meet specific passive fire protection standards (such as BS 476 or EN 13501-1)
    A suspended ceiling can be either a fire barrier, a plenum, or both, depending on how the building's HVAC and fire safety strategies are designed. These two terms refer to entirely different functions—one is a safety rating, while the other is an airflow mechanism
