In a domestic TN-C-S installation, the housholder has had a gas hob installed. The supply is piped directly though the wall immediately behind the new hob outside to a changeover/ regulator connected to two 47kg propane cylinders which sit on the ground. The supply piping is all above ground. Is it necessary to bond the metallic supply piping and can anyone offer a simple explanation for a sceptical householder?
Thanks.
