HV Switchgear - Transformer Separation
Good Morning all,
I am seeking guidance on whether high-voltage switchgear and the associated transformer can be located within the same enclosure. My initial thought is that this practice should be discouraged due to fire separation concerns. I would appreciate your insights on this matter, and if anyone could direct me to a relevant clause or standard that addresses this issue, I would be very grateful.
Many thanks in advance.
Matt Murphy.
Parents
  • The suitability of locating high-voltage switchgear and the associated transformer within the same enclosure depends on the system design, equipment type, voltage level, installation environment, and the applicable regulations.
    Your concern regarding fire separation is valid, particularly for oil-filled transformers, where fire risk, oil containment, ventilation, and arc-flash considerations must be carefully addressed. In many installations, transformers are separated from switchgear rooms to reduce the risk of fire propagation and to improve operational safety. However, some modern packaged substations and integrated switchgear-transformer units are designed and tested for installation within a common enclosure, provided they meet the required fire, insulation, protection, and safety requirements.
    Relevant standards to consider include:
    • IEC 61936-1 – Power installations exceeding 1 kV AC: requirements for design, installation, and safety of high-voltage installations.
    • IEC 62271 series – High-voltage switchgear and controlgear standards, including requirements for switchgear assemblies and enclosures.
    • IEC 60076 series – Power transformers, covering transformer design and performance requirements.
    • BS 6622 / BS 9999 (where applicable in the UK) – Fire safety considerations for electrical installations and building design.
    The key factors are usually:
    • Transformer type (oil-filled vs dry-type)
    • Fire rating and construction of the enclosure
    • Oil containment arrangements
    • Ventilation and pressure relief provisions
    • Separation distances and access requirements
    • Manufacturer’s installation instructions and certification
    Rather than a blanket prohibition, the decision should be based on a documented risk assessment and compliance with the relevant standards. For oil-filled transformers, physical separation is often the preferred approach unless the enclosure has been specifically designed and approved for combined installation.
    It would be useful to know the transformer rating, voltage level, whether it is oil-filled or dry type, and the country/standard framework being applied, as the requirements can vary.
  • Thank you for your detailed response, Terry, and for providing the references to the standards; they are very helpful. This morning, I received information from the M&E design team indicating that the transformer is a "dry type." This is a UK commercial transport project, but I currently do not have any additional information, such as the precise voltage level.
  • Very detailed response, I learnt from it as well. Thanks!
  • Thanks
Reply Children
No Data
