Most people think 5G is about speed. And yes, faster downloads are part of the story, but speed is the easy bit. The really interesting transformation is happening underneath, in the architecture. Three technologies, 5G Standalone, Voice over New Radio, and Network Slicing, collectively change what a mobile network can be: not just faster than 4G, but fundamentally smarter.
5G Standalone: breaking free from 4G
When operators first launched it, most did not build a new core network, they bolted 5G radios onto the existing 4G core, a mode called Non-Standalone (NSA). It was pragmatic and got 5G to market years earlier. But when your 5G radio is anchored to a 4G core, you inherit that core’s limitations: its latency, its rigidity, its inability to support the features 5G was actually designed for. You get a faster radio. You do not get a smarter network.
5G Standalone (SA) removes the 4G anchor entirely. Both the radio and the core are native 5G, and the core is a different beast altogether, cloud-native software services talking to each other over standard interfaces rather than monolithic hardware boxes. That shift is what makes the network programmable: functions can be scaled, automated and even pushed to the network edge, close to the user, which is what unlocks genuinely low latency for things like industrial automation and connected vehicles.
Put simply: NSA gets 5G working quickly using existing investment. SA builds the network that was actually designed.
VoNR: voice, finally native to 5G
Here is something that surprises people: on most 5G networks today, the moment you make a phone call, your device quietly falls back to 4G, carries the call as VoLTE, and returns to 5G when you hang up. It works, but it adds call setup delay, signalling overhead, and a permanent dependency on 4G coverage.
Voice over New Radio (VoNR) carries calls natively over the 5G radio and core, end to end. Calls connect noticeably faster without the fallback handover. Audio quality improves through the Enhanced Voice Services codec, wider audio bandwidth, better noise handling. And voice and data finally coexist cleanly on the same connection.
Getting there is genuine engineering graft. Voice is unforgiving: a lost packet in a download is invisible, but a lost packet in a call is a glitch your customer hears. Coverage must be contiguous, handovers seamless, and the quality-of-service framework precisely tuned so small, regular voice packets are protected amid a flood of data traffic. That is why I treat VoNR as a maturity test: if an operator runs VoNR reliably at scale, you know their entire 5G architecture, core, voice platform, radio, is working end to end. It also matters for what comes next: networks cannot fully retire legacy 4G layers until voice no longer depends on them.
Network Slicing: one network, many personalities
Of the three, slicing has the most transformative long-term potential, and is the hardest to explain without the right framing. Here is the framing that works: think of a major airport. One physical building, but inside it are completely separate zones, departures, arrivals, cargo, staff operations, each with its own access rules and performance requirements. They share walls and a roof, but they do not interfere with each other.
Network Slicing does this for mobile networks. One physical infrastructure, radios, transport, core, logically partitioned into independent virtual networks, each tuned to a purpose. One slice optimised for high-throughput consumer broadband. Another guaranteeing ultra-low latency and high reliability for industrial control. A third handling millions of low-power IoT sensors that prioritise density and battery life over speed.
Picture a smart factory: a low-latency slice runs the robotic arms, a high-bandwidth slice carries HD inspection cameras, and a sensor slice quietly collects environmental data, all on one physical network, each with guaranteed resources and its own security boundary.
This is also where the business model shifts. For the first time, operators can sell differentiated network performance as a product rather than connectivity as a commodity: latency guarantees for enterprises, temporary capacity for stadium events, isolated high-reliability slices for healthcare or public safety. Slicing turns the network from a product into a platform.
How the three fit together
These are not separate features, they are a system. SA is the foundation: without a native 5G core, neither VoNR nor slicing exists in full form. VoNR proves the architecture works end to end. And slicing is where the architecture finally delivers its value.
Think of it as layers: SA builds the house. VoNR proves the plumbing works. Network Slicing lets you reconfigure the rooms for whoever needs to live there.
The networks being built today will carry everything from a teenager’s video stream to a surgeon’s robotic instrument, and the architecture has to handle both. That is not a small ask, and it is why this trio matters far more than another headline speed test.
The views expressed are my own. This article describes industry-wide architecture and standards (3GPP Release 15 onwards) and does not reference any specific operator's deployment.
