Have a look and let us know what you think?
Any technical questions or points you want to raise, then comment below and we will get to them.The document describes an approach, based on a hierarchy of risk control measures. It adopts a holistic risk management methodology using the 4Ps of Predict, Prevent, Process and Protect to ensure that arc flash hazards are systematically identified, analysed and prevented from causing harm.
Removal of the hazard through working only on or near equipment that is made dead and suitably isolated should always be the first-choice risk reduction measure. However, other prevention measures are identified that fall into the categories of automatic disconnection of supply, equipment design and/or operational measures, that can be adopted individually or collectively to ensure safety.
Considerations for flame resistant personal protective equipment (PPE), as a risk control measure, should only be adopted as a last resort principle. This fact file provides an assessment process and there is also a commentary on recognised standards and test methods for PPE in Appendix 2.
Arc Flash Risk Management - A health and safety factfile provided by the IET
