We are pleased to share our 18 free activity sheets to test key GCSE DT skills for teachers to use in class and for young adults to practise independently. (Some topics are in the maths curriculum too.) Maybe your family might even like to partake in a challenge this festive break!
Download individually below or visit the webpage to find out more.
- Can you calculate the area of the shapes on this activity sheet?
- Can you calculate the mass of the objects on our activity sheet and work out the density?
- See if you can calculate costs that go into the making of a single product.
- What is Ohm’s law? Test your knowledge around current, voltage and resistance in an electrical circuit.
- Download our free activity sheet to practise and master Pythagoras theorem.
- Download our free ratios worksheet and see if you can work out the relationships between the numbers.
- Read data, work out what it means, and show in a graph? No Problem. Practise your key skills with our data plotting activity sheet.
- Test yourself with calculations around pressure and applying force.
Stress, strain and Young’s modulas
- See how much you know about testing the strength of a material as you examine stress, strain and Young’s modulas.
- Are you planning on being 50% more productive in 2022? Practise key percentages and fractions skills with our free activity sheet.
- Much. Data? Not a problem when you sort a table so it makes sense. Test yourself with our free activity sheet and practise key GCSE DT skills.
- X and Y! Can your students interpret the graphs in our activity sheet?
Metric units and standard form
- Can you convert the various units of measure into shorter, standard form?
- Can you work out which shapes are needed in these repeated patterns?
- Most products are made to specific sizes. Can you work out the minimum and maximum acceptable sizes for the products on our free activity sheet?
- Can you calculate angles and lengths in a triangle? This activity sheet practises trigonometry.
- Visualising forms of 2D and 3D objects is a core skill for design and technology GCSE.
- Can you work out the volumes of the shapes on our activity sheet?
Download individually above or visit the webpage to find out more.
