3 minute read time.
I’ve worked on enough MVHR (Mechanical Ventilation with Heat Recovery) installations now to know that a design can look perfectly reasonable on a drawing and still become a completely different proposition once you get onto site.
One project in particular brought that home to me. The MVHR design itself made sense on paper. The required extract and supply points were there, the duct routes had been considered and technically the system worked.
The problem was that the building didn’t quite agree with the drawing.
A central corridor formed the main route through the property, and once the other services and the actual construction were taken into account, the available space for the ductwork was far more restricted than it first appeared.
That is where MVHR design becomes less about drawing lines between rooms and more about understanding how the system is actually going to be installed.
When the drawing meets the building
On site, you quickly start asking questions that aren’t always obvious from a plan.
Can the duct physically get through that space? Can the required bend radius be maintained? What other services need the same route? Are we creating unnecessary bends or restrictions simply to follow the original drawing?
And, importantly, can somebody actually install and maintain what has been designed?
On this particular project, blindly following the original routes would have made the installation unnecessarily difficult and potentially compromised the finished system.
The answer wasn’t to abandon the design principles. It was to work with the building.
We looked again at the available routes, coordinated with the other trades and adjusted the installation while still maintaining the intended performance of the MVHR system.
That experience reinforced something I’ve seen repeatedly during my time working on high-end residential projects: buildability needs to be considered as part of the design, not after it.
MVHR doesn’t exist in isolation
Another lesson I’ve learned is that MVHR cannot be designed as though it is the only service in the building.
On a modern property, the same ceiling voids and service routes may contain electrical containment, plumbing, heating pipework and other mechanical services.
Everybody wants the straightest and easiest route.
If those systems are designed independently and coordination is left until installation starts, somebody eventually has to compromise.
With MVHR, that compromise can mean additional bends, longer duct runs or awkward routing. Individually, these changes may seem minor, but together they can affect resistance, airflow and ultimately how easily the system can be commissioned.
Early coordination makes an enormous difference.
Sometimes moving a route slightly at the design stage can save hours of work on site and produce a better installation.
Installation experience changes the way you design
Working on these systems has certainly changed the way I look at drawings.
I no longer just ask whether a route works technically. I try to imagine installing it.
Where will the duct actually run? What is above the ceiling? How will it cross other services? Can we get the duct into position without introducing unnecessary bends? Can the system still be accessed later?
That practical perspective can identify problems surprisingly early.
It also highlights the value of communication between designers and the people carrying out the installation. Neither side should really operate in isolation.
A designer understands the intended performance of the system. The installer sees the physical constraints of the building.
The best result comes when those two perspectives meet.
The lesson I’ve taken from it
MVHR is a relatively simple concept: remove stale air, recover heat from it and provide fresh air to the occupied spaces.
Delivering a genuinely good installation is more complicated.
Airflow calculations, duct sizing and equipment selection obviously matter, but so do coordination, access, routing and the realities of construction.
The biggest lesson I’ve taken from installing MVHR systems is therefore a straightforward one:
A design isn’t successful simply because it works on paper. It is successful when it can be built, commissioned and maintained while still delivering the performance it was designed to achieve.
For me, that is where good engineering and practical experience come together.
