It could be said Systems Engineering and Aviation were made for each other
The invention of heavier-than-air flight has made the world smaller, easier to reach, particularly after 1950. As aircraft capability has grown, the machines themselves have become, as we shall see, vastly more complex.
The aerospace sector manufactures products that can be used in a variety of different contexts:
- Civil aerospace sector using aircraft and helicopters to transport passengers and goods
- Defence Aerospace sector extending from Civil Aerospace use case to include military applications (weapons and defence uses)
- Commercial Aerospace where aircraft and helicopters act as couriers
In addition to these products, multiple related infrastructures, subsystems, and personnel provide key support for Aerospace products.
Why Aerospace matters
The UK Aerospace sector in 2021, was estimated by the main UK aerospace trade association ADS as having an annual turnover in the region of £22.4 billion. £15.2 billion of this was provided by exports of UK aerospace products. In addition to which, the UK aerospace sector had 111,000 direct employees. The EU Civil Aerospace sector in 2020 (non-defence related), was estimated by the main EU aerospace trade association, ASD as having an annual turnover of €99.3 billion, with exports of €88.3 billion and employing more than 371,000 people.
Systems Engineering in Aerospace
Aircraft contain vast amounts of finished parts, which may be formed from several other lower-level finished components. These are sourced from between hundreds up to thousands of different suppliers, drawn from multiple sectors located in numerous countries.
To take one example - the Airbus A380 is one of the world’s largest civil aerospace passenger aircraft. It consists of four million individual components, of which 2.5 million were sourced from 30 countries. With such complexity, Systems Engineering (SE) plays a key role in the design, monitoring, and control of super diverse Aerospace supply chains. The table shows some examples (non-exhaustive) of the multi-year, multi-phases of activity related to a new Aerospace product, highlighting some key tasks where SE plays a pivotal role, from initial conception, design, and testing phases through to the new product being released onto the marketplace:
Phase & Typical Activities |
SE Tasks |
Conception Phase: (idea generation): Internal or external requirement(s). Generate initial project proposal. Gated internal and external review. |
Identify and refine conceptual requirements. Generate initial systems boundary/context diagram of internal and external actors. |
Planning Phase: Stakeholders identified and engaged. Project documentation generated (plans, logs, registers). Requirements captured, reviewed, and agreed with stakeholders. Gated internal and external review. |
Visualise ‘Whole Systems Thinking.’ Undertake Suppliers, Inputs, Processes, Outputs, Customers (SIPOC) analysis based on identified key stakeholders. Generate a Requirements Traceability Matrix (RTM). For each requirement, clearly identify how it will be undertaken, by whom, duration of activity (optional), and expected outcomes, using earlier SIPOC analysis. Review initial project plan with stakeholders undertake a Process Failure Mode Error Analysis (PFMEA)72 feedback data on initial project plan. |
Design Phase (define how to make products): Identification of a Technical Design Authority (TDA), that generates technical documentation:
Review outputs from earlier planning phase SIPOC, RTM, PFEMA analysis. Review outputs from TDA technical documentation. Analyse the flow of information (and physical items) between different internal/external actors, consider triggers/requirements, look for potential areas of concern (roadblocks). Generate:
Circulate documents to the identified internal and external actors. Undertake a PFMEA activity to identify any unforeseen risks / issues, applying appropriate mitigation tasks. |
Technical Phase (prototyping and testing): Detailed technical GAP analysis identifies new materials or manufacturing process changes (actors, tasks, durations, costs). Validate and schedule any required changes with applicable functions. Sourcing and scheduling activities. Production of prototype batch. Technical documentation generated and reviewed. Technical documentation status set to Pre-Released (Pre-Rel). Gated internal and external review process. |
Ensure ‘whole system thinking’ is applied to the entire value chain of the required product(s), consisting of multiple tiers of suppliers spread across multiple locations globally. Record all cradle-to-cradle activities relating to the product: 1. Extraction of minerals; 2. Processing into chemicals; 3. Formation of mixtures and materials into raw materials; 4. Initial internal sourcing of raw materials; 5. Transportation to internal/external facilities; 6. Initial activities undertaken; 7. Subsequent transportation; 8. Further activities undertaken by internal/external facilities; 9. Generating semi-components; 10. Repeating analysis steps 1 to 7 for components; 11. Repeating analysis steps 1 to 7 for assemblies (if applicable); 12. Repeating analysis steps 1 to 7 results in finished product; 13. Recording applicable inspection and testing activities. The data to be recorded at each step should include duration, resources (people, energy, water), emissions (air, water, soil), waste and recycling, ethical behaviours (wages, diversity, anti-bribery, etc.). Capturing such information at the system level enhances an organisation's ability to analyse any environmental and sustainability impacts related to the product. Record progress and deviations from planned to actual activities. Examine reasons for deviations and make necessary adjustments. |
Operational Readiness Phase (production release approval): Update Sales and Purchase Order books to capture sales data triggering internal systems to schedule resourcing and procurement of required materials. Create support function training and documentation. Complete the final updates to technical documentation. Technical documentation status set to Production (Prod). Gated internal and external review process. |
Shutdown Phase (final review and handover): Complete all documentation. Handover project to support function. Conduct final review of project with all stakeholders. Identify issues and suggestions for improvements that may be used by the other projects. |
Post operational phase, quality control measures monitoring production, engaging with stakeholders, listening to feedback from all actors, implementing incremental changes will ensure consistency of the system and product is maintained. |
Aerospace Systems Engineering Lifecycle Activities Outline
Source: Ramon Kagie on Unsplash
Challenges in applying SE in Aerospace
The increasing dependence on data and systems and the increasing need to demonstrate safe aerospace operations mean SE will play an increasing role in aerospace products and services.
Aerospace OEMs (Original Equipment Manufacturers) historically designed and made most of their products internally. Despite lengthy lead times for the design and manufacture of its products, the Aerospace sector has remained on a constant upward trajectory. As the tempo of globalisation increased from the 2000’s onwards, the Aerospace sector initially resisted outsourcing the manufacturing of products to external, lower cost facilities in the Far East. By the mid-2000's, outsourcing to east Asia had become the norm, allowing Aerospace companies to meet the ever- increasing demand for products, whilst maintain price competitiveness with each other. There was a lack of ‘whole system’ methodology in terms of analysing both the supplier and all the sub-tiers that provide materials, products to the supplier under assessed. The adopted assessment methodology was more focused on supplier certification, ability to supply products in the right volumes, low cost, up to assuming a level of quality, which resulted in these key incidents:
- Kobe Steel Scandal: In 2018 a very reputable Japanese steel manufacturer adopted a process that supplied initial shipments of metal at the precise customer requirements and certified to agreed quality standards to Aerospace, Automotive and Rail sectors, followed by sourcing much inferior quality metals from non- approved suppliers as a standard business practice
- Boeing Dreamliner Scandal: Numerous incidents in the development cycle of the Boeing 737 max: (a) changes made to the ‘safety cage’ software of the aircraft by cheaper, inexperienced replacement developers, without controlled processes. This contributed to two major air crashes; (b) Airworthiness authorities around the world grounded all Boeing Dreamliner 737 Max, resulting in service disruption, regulatory fines, loss of revenue and a damaged reputation for Boeing
- China Forced Labour: Persistent international media reports and studies relating to the forced camps holding Uyghur Muslims in the Xinjiang region of China, being used to produce materials (aluminium, cotton, silica), and resultant products which are widely used by multiple industry sectors, and then sold to vast numbers of global consumers. This resulted in the: (a) 2021 US Uyghur Forced Labor Prevention Act (UFLPA) which came into effect in June 2022, banning all products from China’s Xinjiang region, this resulted in major Aerospace supply chain disruptions; (b) in 2022, Europe has proposed a similar but much broader type a regulation, whilst not directly naming China, covers potentially banning any product entering Europe, as either imported products from such regions or exported where EU companies have consumed those products into more complex objects.
These examples demonstrate how SE was not applied early enough in the product development. Instead, much simpler initial reviews were conducted. A ‘Whole Systems’ methodology would have identified potential risks much sooner.
Aerospace is a global production and service operation industry that is under pressure to reduce costs and delivery timescales. It is under economic pressures to maximise efficiencies alongside regulatory, safety and service quality pressures to improve performance. SE activities have the effect of increasing those pressures in the short-term through more detailed, lengthier, and increased-cost perspectives. Engaging in, and with, SE activities creates more robust analysis, with improved long- term outcomes.
Share your thoughts!
What role can Systems Engineering play in making aviation more sustainable?
How can Systems Engineering simplify modern procurement of components and make aircraft production simpler?
What role does systems engineering play in ensuring the safety and reliability of complex aerospace systems?
#thewholesystem
