Often, in high profile transactional environments, the tech stack is constantly in a state of tactical or strategic flux. It organically builds where it heads to either a bottleneck of services or where the ability to scale is diminished - simply because the clutter is too much. Whilst business managers may use tracking schedules of a project to give a sense of accountability, technology focused individuals usually derive the same level of accountability using role based access methods (RBAC). The project or company can further combine the managers project schedule and the role base access methods implemented to create an oversight framework using models such as the Bell–LaPadula or Biba Model on how controls tie back into the security of the business proces.
RBAC is a strong method that almost sits in between the layers of tactical and strategic flux that provides either a point of solid triage or the ability to introduce a committed structure that is accountable to the highly dynamically changing technology estate. Across modern technology stacks, RBACs can be applied at either the operating system level, application level or even access level. This fluid ability ensures that user accounts, separation of privilege levels, hierarchy of roles, permissions and groups give a stronger accountability of compliance relief.
It ensures that no matter if you are in a tactical or strategic deployment, coarse grain permissions are correctly implemented at a foundational layer, thus allowing you to combine roles and privileges based on activity required. It therefore inherantly extends out into cloud and hybrid environments that use Single-Sign-On, Two Factor or Biometrics to complement the RBACs model against Aceess Controls Lists, Mandatory Access Control and the Access Control Matrix used.
With the ever changing platforms of transactions, role based access not only allows you to introduce a level of stability within the platform; it is a progressive approach that will also fuel technology innovation.
