Correctly installing fire doors and doorsets and their on-going repair and maintenance is critical to the safety of building occupants. Fire doors play a vital role in containing fire and the spread of smoke in the event of a fire.
The importance of good installation cannot be overemphasised. Poor installation can mean that an otherwise well-manufactured door fails to provide the required performance in the event of a fire. The installation of a doorset is as much a part of the fire resistance test as the doorset itself. Therefore, any alterations to the method of installation must be covered by a test report, an assessment report or an extended field of application report.
Repair and maintenance of a life-safety device such as a fire door is imperative. Generally, after handover, this responsibility passes to the building owner. Ongoing maintenance should be considered a preventive measure to ensure that the doorset operates correctly at all times. Where problems are identified it is extremely important that a system is in place to ensure that timely corrective action takes place so that failure of the doorset is prevented. It is strongly recommended that a scheduled programme is implemented and that any maintenance undertaken is carried out by a company that is certified for this type of work.
Course objectives:
Thorough understanding of the regulations and standards applying to fire doors
Knowledge of the different types of fire doors and their installation, repair and maintenance.
Appreciate the importance of critical components such as door closers and hinges
Understand how to set up hinged doors to comply with disabled access requirements.
The day concludes with a short exam.
Details and pricing: http://bit.ly/1Aa7Sko
