Fundamentally, the desired result of a diagnostic test is to determine the status of the apparatus as to whether an abnormality is detected, how critical it is, and how soon it will require attention. The justification for the tests is the benefit of having data to support decisions that affect the reliability of the asset. Short of limiting the use of an asset, diagnostic testing is the only reliable and economic approach to ensuring its longevity for reliable and safe operation.
 Some tests can detect very specific anomalies while others offer a broad assessment of the asset. The scope of this presentation is to consolidate all the current techniques ranging from simple insulation resistance testing to more complex methods such as Frequency Response Analysis for field testing of HV assets using both on-line and off-line techniques and to identify each test’s true capability. The assets are transformers and bushings, rotating machines (HV Motors and Generators), switchgear, surge arresters and cables. Case studies will be included to illustrate the value of the diagnostic test tools.
Karl Haubner joined Doble Engineering in October 2004 and is employed as the High Voltage Test Application Engineer servicing the Asia-Pacific region. Prior to his appointment with Doble Engineering he worked for the utility Western Power. As the Superintendent of the HV Test Laboratory, he was responsible for all technical aspects of the test group such as development and introduction of new condition monitoring techniques on distribution, transmission and generating assets.
He is the author of several technical papers on condition monitoring of HV assets and cable fault location and has delivered short courses on testing techniques at University and Industry level. Karl is member of Cigre Australian Panel D1 and Australia Standards Committee EL-007.
Robert Heaton
