Looking for help with a moving coil RIAA Pre amp
    Hello Matt,
    You can see the circuit diagram of a Moving Coil Phono Preamp without opamp ic's (by the very well-known audio designer John Linsley-Hood) by using the following link:
    http://sound.westhost.com/project25.htm
    It is designed for +-5 Volts supply, but the addition of a pair of three terminal voltage regulator ic's with a +5V and a -5V output will enable +-15 Volts operation.
    I hope you find this circuit of interest.
    John
    Hello John
    Many thanks for the reply and a place to look, the circuit looks fine and as you say I can soon ajust the voltage.
    Once again many thanks Matt
