Time to create a new professional registration for Engineering Technologists
The number of newly registered incorporated engineers continues to decline. The strategy of the Engineering Council is clearly not aligned to supporting the engineering technologist professional. Given the governments commitment to technical education the IET should create their own professional register to provide a relevant standard. It is obvious the current UKSPEC standard lacks credibility in terms of the IEng grade
  • John Bowman,
    Firstly, I am FIET but MIET, but that's only a recent change. I'm not sure why you ask the question, but never mind, let me mount my challenge to your post. I'm not necessarily responding to every direct of your post, only to those where I take issue.
    On the positive, I do take your point about multidisciplinary engineers, I often perform the multi disciplinary for myself. I don't personally believe that makes a further to professional registration. Though I don't wish to mix up membership category with PR (they are two completely different things) much of my experience in my application to become Fellow were multi disciplinary and that was certainly successful. As a newly appointed PR interviewer, I also believe that multi disciplinary expertise is considered as equally relevant and acceptable as the very narrowest specialist discipline. However, employer's have to consider what set of skills they are seeking, and of they are not seeking multi disciplinary capability, but simply single discipline skills, then why shutoff they but advertise on that basis? If you happen to have skills that exceed them, this is no reason not to apply unless your multi discipline focus has diluted your expertise in the single discipline they seek, in which case they would be absolutely right to exclude you. It can never be illegal or wrong for employers to recruit for a specific skillset or capability.
    You say stipulating C.Eng is illegal. I would very much like to see the law which makes it illegal, if it exists. If you are alleging it is discriminatory on the grounds of where in the world you may have achieved equal registration status, I believe most employers advertise jobs with an overarching "or equivalent' implication, even if they don't say so overtly, and more importantly, most potential applicants know this and don't allow it to discourage them from applying. Maybe it should be stated overtly, but let's be honest, there are so many factors where "or equivalent" would be applicable, it could make job adverts very cumbersome. To illustrate this, I have two management qualifications which are not Master's, but are formally equivalent to Master's. This doesn't prevent me applying for jobs requiring Master's, and I've never known an employer not accept them.
    Also, whenever I have been recruiting (which I haven't done for some time) I have always been ready to interview somebody with alternative qualifications or registration, whether or not that's formal. But let's not forget that C.Eng is still internationally accepted as the gold standard, but should we forget that part of the reason for that is the professional standards, including integrity, that are required in order to maintain that status. It gives employers and clients a route for action in the event of malpractice. Yes, so does I.Eng, but your post does not seem to be about accepting I.Eng in addition to C.Eng, if I understand you correctly, I believe you refer to non UKSPEC accreditation.
    But most of all, my issue is with your statement that the C.Eng/I.Eng distinction is out of date and out of reality. Not so, one bit. They represent to very different types of engineering professional. As several of us have said elsewhere in this thread, it's not about one being better or more senior than the other, but simply at different ends of a broad spectrum. If you don't know what that distinction is, then either read UKSPEC again, or ask for sometime to explain it. And while I definitely true myself behind the push to get requirements shown as C.Eng/I.Eng where either type of engineer would be suitable for the position, as is often the case, if an employer definitely needs an engineer of the C.Eng variety, and doesn't feel an I.Eng flavour would be right, then why should they not recruit in that basis? Indeed, to do otherwise could place the applicant in a vulnerable and undesirable position. It works both ways. There could well be times that they specifically require I.Eng type capability, and could place a C.Eng in a difficult position.
    Admittedly, many, if not most, employers have no understanding of what C.Eng and I.Eng really mean it of the key distinctions, and that's exactly what many of us on this thread are trying to identify an answer to. But the answer to that, if it is ever to be found, lies but in abolition of the two distinct registrations, but in seeking to overcome that knowledge gap.
    I feel the term elitist is a well overused word. Providing affirmation that an individual holds and consistently apples a level of knowledge, expertise and professionalism - including that key distinction between C.Eng and I.Eng of being able to develop new or novel approaches, or adjust existing approaches to address needs, add opposed to selecting from a range of known and tried approaches to identify the most appropriate - is not elitism. It serves as a confirmation to employer/client, the engineer himself/herself, and their peers that this person has those attributes and can be relied on to apply them in their work. It is affirmation to the engineer that s/he is on the right path, and also encourages continuing professional development to maintain those qualities.
    As for the role of the institute in providing knowledge services, that is a completely separate matter and is available equally to all members, regardless of membership grade or registration status.
  • Just to add emphasise to Roy's point, which I have addressed more fully in another thread, it is perfectly legal for UK employers to insist on CEng if they wish - it would be equally legal for them to insist on a GCSE in Classical Civilisations if they wanted (even if it wasn't relevant to the job).
    I have never met an employer who does insist on CEng (or GCSE Classical Civilisations), because in practice this limits their field of choice of candidates too much. But if John has found one, then that's up to that employer. If they feel they can find good enough candidates by using this selection critieria that's up to them.
    Thanks, Andy
  • Just a quick note to all to apologise for the many and horrendous typos in my various posts - the penalty paid for posting from my phone with its amazing predictive text. I always think I've reread to eliminate them yet they still seem to creep in at that last minute as I hit the post button. Hopefully, my intentions will still be clear!
    PS. Andy Millar, absolutely! Employers are entitled to define any aspect of skill, education or experience providing they apply them equally to all candidates and they don't directly or indirectly exclude one of the categories of individual protected by discrimination law (race, gender, religion, sexual orientation, etc.).
    Andy Millar:
    Thanks, Andy
    Andy,
    Re: Time to create a new professional registration for Engineering Technologists
    Posted by Andy Millar on Dec 16, 2017 2:38 pm
    No It is illegal, it is discriminative as confirmed by ECUK what they can ask for is - meeting UK Spec at C Eng leveml or equivalent.
    I have never met an employer who does insist on CEng   But if John has found one, then that's up to that employer.
    Rolls Royce call for CEng for their EPR Nuclear Engineers.
    UKAEA called for CEng (MI Mech E ) for mechanical or cryogenic posts.
    I was deliberately discriminated against. I went from France to JET to explain that IET IEng were equally qualified (Their Chief Eng was only BSc .
    UKAEA now advertise the same Cryogenic eng post as HNC or BSc - It is worth stiking up for your rights.
    It is not because you do not see that it does not exist.
    Those that discriminated against IEng MIET or CEng MIET were made honorary members IET or MIET IEng & CEng.
    And you accept that?
    No - Time to create a UK register of Professional Engineers HNC, BSc  ++++
     - Time to create an association of PEIs in all disciplines of Engineering & Technology.
     - Time to let PEIs of specific disciplines to concentrate on their basic function of information, communication and promotion of E&T.
     - Time to create a true Institute of Engineering & Technology for all multi-disciplines PEs of all grades and genders of UK base or residence.
     - Time to set IET up as an Electrical & IT PEI only (for Ceng) Call it IET Electro-technique Technologists.
     - Time to get rid of this electrical - IT CEng hegemony pf PEs that are out of touch with E&T.
    Just look at the facts & statistics IET has FAILED its members and its objectives.
    John Gowman BA
    Thanks, Andy
    Andy Millar CEng CMgr IET Mentor / IET PRA uk.linkedin.com/in/millarandy
    Andy Millar:
    Thanks, Andy
    Andy,
    John Gowman BA
    Thanks, Andy
    Andy Millar:
    Thanks, Andy
    Andy,
    John Gowman BA
    Thanks, Andy
    Andy Millar:
    Thanks, Andy
    Andy,
    John Gowman BA
    Thanks, Andy
  • Roy Pemberton
    I forwarded your earlier post to the two e-mail addresses on file. One bounced back but perhaps your alias one will work?
  • John, Roy and Andy,
    I think John is making some good points, though I feel that often they are hidden in what looks like a rant against the "cliqueishness of the PEIs" and may be overlooked by many, particularly the need for cross discipline competency and that it is the personal competency that is critical rather than the title, though I have to say I have not experienced any of the elitism of CEng mentioned. I agree with Roy and Andy that it is not illegal to insist on CEng, though I was told (in my previous position where I was recruiting) that any such requirement may need to be justified to show why it is not discriminatory. I always used to ask for "CEng, IEng or equivalent, or able to work towards such registration" or something similar. It did not restrict my choice of interviewees and in fact I looked for the right experience and attitude more than paper qualifications. This is demonstrated in that my most successful recruit was neither CEng nor IEng, and did not even have a degree, but was able to demonstrate that she was by far the best candidate in those critical areas of experience and attitude and made a great success of the position, and now a number of years later is putting together an application for CEng, something she was certainly not in a position to do when she started the job. I even had to defend choosing her with our Global Head of Electrotechnology as he felt from her background she wouldn't be able to cope with the job. He not only changed his mind when he met her, he later stole her from me to work in his group doing even more advanced work.
    Alasdair
  • Hi Alasdair,
    However I think it's important to be clear here that it's only a question of potential discrimination against the "protected characteristics" Roy mentioned earlier, so provided you can show that candidates of different gender, ethinc background, disability etc had equal opportunity to apply for CEng then this would not be - and, as I understand it, is not - a problem. Actually it's a myth - albeit a common myth - that you need to actively show that it is not discriminatory, rather the case is that you need to be prepared to demonstrate to a tribunal why you were not discriminating were a case to be brought against you.
    Cheers, Andy
