UNC and UNF fasteners in Britain
Somebody will know the answer to this…
Almost all British machinery manufactured before 1950 used Whitworth, BSF, or BA fasteners. Manufacturers moved towards using metric fasteners in the 1970s and these have been the most commonly available and used family since 1980, although the proposal to use metric fasteners dates back 1965. Whitworth and BSF officially became obsolete in 1948 following an agreement between the UK, US, and Canada to standardise on the American UNC and UNF fasteners for future use. UNC and UNF fasteners were used in British machinery manufactured in the 1950s, 60s, and 70s where they gradually replaced Whitworth and BSF before themselves being replaced by metric fasteners.
1. Were UNC and UNF fasteners used across most industries in the UK or were they largely confined to specific industries such as automotive and machine tools? Were they regularly used in railways or shipbuilding?
2. Were the numbered sizes smaller than ¼ inch commonly used or did industry stick with BA fasteners until they moved to using metric fasteners?
3. Were UNC and UNF fasteners commonly used in construction? What are the most common family of fasteners used to hold together 1960s tower blocks and university buildings?
4. Was it easy to buy UNC and UNF fasteners from hardware and DIY shops in the 1960s and 70s or did they move directly from selling Whitworth and BA fasteners to metric fasteners?
  • ...and given that no-one on eBay sells the UNC nuts I'm after in the UK anyway (I only need a handful), I'll try BSW and see what happens! Being brass screws they probably are BSW anyway. Brass screws do seem to be the last bastions of imperial threads in the UK, I guess because the threads tend to be coarser. Or because most of us who use brass fixings a lot tend to be terribly old smiley
    Cheers,
    Andy
  • Andy Millar:
    Are the cupboard door knobs American? 99.9% of things with UNC threads are American. If they are British then they will be Whitworth. There is some truth to what you say about the coarser threads in soft metals.
    Brass screws with UNC threads do exist but they are uncommon. Probably because of the American cost cutting culture. Titanium screws with UNC threads are quite common as they are used in aerospace.
  • Now an even more challenging question for anyone: How do you determine whether an internal thread is 3/16 BSF (internal diameter 0.1475 inches, 32 TPI) or 2BA  (internal diameter 0.1467 inches, 31.4 TPI)? Now because that's far too easy ? I'll add that the first couple of threads are damaged so I can't just try a screw of each size in it - I'm going to need to buy a tap to "reform" the thread. And if it's the wrong one it will just completely destroy the rest of the thread.
    To be honest, since it's in a UK built milling machine from 1940s-1950s I'm 99.9% confident it will be BSF, but it will be very embarrassing if I get it wrong - I'm assuming that the steel's going to be pretty resistant to drilling out and retapping!
    Having finally got around to fitting a new chuck to my lathe which involved tapping a 3/4" BSF thread in the backplate I feel like I'm on a roll now - this milling machine's been just sitting there for about 15 years waiting for me to get around to replacing this tiny (but very vital) screw ?
    Cheers,
    Andy
  • you wont tell on the diameters, as the tolerances will overlap. 2BA is large enough to take a 'cast' of the thread profile - a match stick and wax or soap or at a push blue-tac should do the trick, or depending how the threads are damaged a 'screw' from a plain brass rod coated in soft solder.
    There are 2 things,  all BA have a 47degree pitch angle, as opposed to 55 for whitworth and 60 for metrics and UNF,  so a look at the thread depth, and if the hole goes deep enough, then you may get something on TPI.
  • Andy,
    Your best bet is probably to buy a set of thread gauges to check the thread (you may need to buy a set of BSF and a set of BA, but if you suspect it is BSF then that set will probably be all you need). You can then check the thread pitch as a thread gauge about 1" long should easily identify the difference. Granted it may be a one off expense that you only use once at £5-10 per set, but if it is what is needed to avoid wrecking an expensive piece of equipment may be justified.
    Alasdair
  • I fear, as 2BA is about 4 or 5mm dia, and thread pitch 0.81mm  (0BA is practically M6, 6mm dia, and 1mm pitch, and each higher  BA size is 90% of the dimensions of the preceding.)
    You may not find it possible to get a gauge that is thin enough to fit down hole and engage sufficiently convincingly to be sure. Depending on the hole depth and the how much is damaged it may be safer to taper ream the damaged turns until a bolt fits. (and note that a brass bolt will reveal binding without damaging the steel, though go gently, you do not wish to snap the head off.)
  • Mike, this is true but a combination of the cast you suggest and a thread gauge should work.
    Alasdair
    Andy,
    Can you say what make and model of milling machine this is?
    Someone may have access to a parts catalogue which may indicate the screws used.
    I have found this a lot with older machines when I used to have to repair them, the manuals can be useful to identify threads, even when a hundred miles away from them!!!
    I used to do so much I ended up with a full set of BSW & BSF taps.
    It was rare in my experience to find BA threads on anything other than electrical or automotive equipment.
    Machinery tended to be BSW/F on the mechanical bits.
    Your other option is to drill it out and "Helicoil"* it.
    That way you would know it is 3/16" BSF.
    Unless it is a liquid tight thread this may well be the easiest option, and there are ways around sorting it out if it's a liquid tight thread.
    You can by a kit with 10 1.5xD inserts for around 40 Euro direct from the manufacturer including tax & delivery to the UK.
    *Other manufacturers of wire thread inserts are available.
  • If only the first couple of threads are damaged then it might be the best choice to carefully ream them out. Once the damaged threads are removed then a bolt can be inserted into the hole which will engage with the remainder of the threads that are undamaged. There is probably no need to re-tap the hole if there are a sufficient number of undamaged threads remaining.
  • Sorry for the slow reply to all the excellent replies - I was trying to get work finished before holiday, and then I was being away on holiday Relaxed
    Yes, I'd wondered about trying the matchstick (or toothpick) and wax / blue tac idea, the problem is that it is the hole is so small that might be challenging, particularly given the tiny difference in thread pitch I'm trying to measure.
    The manufacturer is something like "Tew & Sautkey" - it's cast in under a layer of thick enamelling so not easy to make out. I can't find a reference to them (or any name like that) anywhere, if this rings any bells with anyone it would be very interesting to know.
    I'll get hold of a 3/16 BSF screw (I've already got loads of 2BAs) and have a play - I might try gently grinding down the first couple of damaged threads with a cone shaped grinder in a Dremel. If nothing else that'll give me a clue as to how hard this bit of steel is.
    But I will get myself a set of imperial thread gauges anyway when a nice set comes up on eBay etc...I've also just had to work out what the thread is on the drawbar for the chuck so I can buy some new collet chucks, but as that was 3/8" BSW that was easy - (relatively) big and chunky!
    Cheers,
    Andy
