Data protection info
Hello,
I've just gone hunting for info on data protection guidelines for volunteers. It seems like this page is defunct, and should probably be removed completely (the links don't work):
http://www.theiet.org/volunteers/resources/policies/data-protection.cfm
I found this page instead, which seems to be current:
http://www.theiet.org/volunteers/active/how-iet-works/data-protection.cfm
Just a heads up for anyone else looking for this information.
    I am wondering if it is possible for the web administrator to redirect the first link to the second one.
    Thanks for alerting us to this Manish. I will get in touch with the adminstrator and suspect you are correct that the first link needs to be archived and redirected.
  • Hi Manish - thanks for letting us know about the problem regarding the Data Protection content.
    This is a known issue - it appears to be a glitch in our Content Management System which results in certain items of content not archiving correctly. This page was archived back in 2014 but for some reason it is still showing up even though the PDF files are no longer available. It is something that our IT Team are aware of and are looking in to.
    The second link (www.theiet.org/.../data-protection.cfm) is the most up-to-date content and it's this page that we will continue to update.
    For future reference, you can find most of our generic resources for volunteers via the 'You as a volunteer' page http://www.theiet.org/volunteers/active/talent-support/index.cfm
    Thanks again for flagging this to us and please let us know if you spot anything else. yes
