Arduino ADC usage
Hey all, is anyone savvy with arduino boards?
I'm looking to use one to perform an analog to digital conversion on a measurement signal coming from a sensor.
The signal range is up to around 9V so I've potential divided this down by half so any value should be readable by the adc.
I've then used the analog read function on a0 and then done some cals to work out the source voltage and corresponding sensor pressure.
What I'm struggling with is the input to the arduino, because when using the serial monitor the ADC signal outputted is seemingly random, and goes up and up then begins at zero again.
Is this pin float? I feel like it is.
  • I've done a little with Arduinos (and Raspberry Pis)
    Presuming nothing has mis-configured the A0 pin (e.g. https://docs.arduino.cc/learn/microcontrollers/analog-input ) and everything's connected correctly I'd expect it to work. What sort of calculations are you doing? - you can certainly get odd effects if you inadvertently use integer rather than floating point arithmetic with small or large values or forget to initialize things when looping.
  • Calculation wise its just first print the raw ADC value, then print the analog voltage value. Then double that (as its potential divided down) and then use that value to calculate the pressure based on the sensor data sheet equation.
    I can seem to get it to work in software on tinker cad using an uno, but in practice using a nano physically the output for the adc just wanders about from 0 up to 1023 in steps then repeats.
    It's not something to do with a pull up being defaulted on?
  • Maybe I'm not picturing it right, but I can't see a simple pull-up resistor causing the input to ramp up over time let alone rest to zero and repeat.
    I can only suggest cutting the problem in half - replace the sensor & potential divider with something simple - e.g. a pot (variable resistor) and see if the arduino then behaves as you expect as you twiddle it  - that should tell you if the problem is on the arduino side or sensor side.
  • I think it's the arduino side, as I've removed everything and I'm just reading the ADC output on A0 using AnalogRead(A0).
    I'm getting a varied output like this:
    08:34:47.456 -> ADC Value :524.00
    08:34:48.485 -> ADC Value :297.00
    08:34:49.561 -> ADC Value :242.00
    08:34:50.587 -> ADC Value :229.00
    08:34:51.659 -> ADC Value :234.00
    08:34:52.690 -> ADC Value :228.00
    08:34:53.765 -> ADC Value :234.00
    08:34:54.793 -> ADC Value :228.00
    08:34:55.867 -> ADC Value :234.00
    08:34:56.895 -> ADC Value :227.00
    08:34:57.970 -> ADC Value :233.00
    08:34:58.999 -> ADC Value :228.00
    08:35:00.074 -> ADC Value :232.00
    08:35:01.105 -> ADC Value :228.00
    08:35:02.134 -> ADC Value :230.00
    08:35:03.209 -> ADC Value :230.00
    08:35:04.236 -> ADC Value :228.00
    08:35:05.314 -> ADC Value :233.00
    08:35:06.342 -> ADC Value :225.00
    08:35:07.418 -> ADC Value :235.00
    08:35:08.446 -> ADC Value :223.00
    08:35:09.522 -> ADC Value :235.00
    08:35:10.555 -> ADC Value :224.00
    08:35:11.632 -> ADC Value :232.00
    08:35:12.660 -> ADC Value :228.00
    08:35:13.739 -> ADC Value :227.00
    08:35:14.766 -> ADC Value :234.00
    08:35:15.843 -> ADC Value :223.00
    08:35:16.873 -> ADC Value :235.00
    08:35:17.905 -> ADC Value :225.00
    08:35:18.980 -> ADC Value :231.00
    08:35:20.010 -> ADC Value :225.00
    08:35:21.087 -> ADC Value :228.00
    08:35:22.116 -> ADC Value :230.00
    08:35:23.194 -> ADC Value :223.00
    08:35:24.222 -> ADC Value :230.00
    08:35:25.300 -> ADC Value :222.00
    08:35:26.329 -> ADC Value :231.00
    08:35:27.405 -> ADC Value :225.00
    08:35:28.435 -> ADC Value :226.00
    08:35:29.510 -> ADC Value :230.00
    08:35:30.535 -> ADC Value :223.00
    08:35:31.608 -> ADC Value :232.00
    08:35:32.635 -> ADC Value :221.00
    08:35:33.707 -> ADC Value :232.00
    08:35:34.731 -> ADC Value :220.00
    08:35:35.804 -> ADC Value :232.00
    08:35:36.831 -> ADC Value :221.00
    08:35:37.904 -> ADC Value :230.00
    08:35:38.927 -> ADC Value :222.00
    08:35:39.994 -> ADC Value :229.00
    08:35:41.063 -> ADC Value :223.00
    08:35:42.091 -> ADC Value :224.00
    08:35:43.165 -> ADC Value :228.00
    08:35:44.191 -> ADC Value :223.00
    08:35:45.263 -> ADC Value :230.00
    08:35:46.292 -> ADC Value :221.00
    08:35:47.368 -> ADC Value :231.00
    08:35:48.398 -> ADC Value :222.00
    08:35:49.467 -> ADC Value :231.00
    08:35:50.492 -> ADC Value :219.00
    08:35:51.561 -> ADC Value :232.00
    08:35:52.621 -> ADC Value :218.00
    08:35:53.649 -> ADC Value :229.00
    08:35:54.718 -> ADC Value :222.00
    08:35:55.790 -> ADC Value :230.00
    08:35:56.816 -> ADC Value :223.00
    08:35:57.892 -> ADC Value :225.00
    08:35:58.918 -> ADC Value :226.00
    08:35:59.989 -> ADC Value :221.00
    08:36:01.014 -> ADC Value :228.00
    08:36:02.087 -> ADC Value :219.00
    08:36:03.116 -> ADC Value :230.00
    08:36:04.189 -> ADC Value :218.00
    08:36:05.216 -> ADC Value :231.00
    08:36:06.288 -> ADC Value :219.00
    08:36:07.316 -> ADC Value :228.00
    08:36:08.389 -> ADC Value :222.00
    08:36:09.413 -> ADC Value :224.00
    08:36:10.480 -> ADC Value :227.00
    08:36:11.549 -> ADC Value :218.00
    08:36:12.573 -> ADC Value :230.00
    08:36:13.636 -> ADC Value :218.00
    I'm gonna try another arduino board, just to rule it out.
  • Trying an official Uno board now and the result seems much closer together.
    08:45:54.107 -> ADC Value :169.00
    08:45:55.134 -> ADC Value :155.00
    08:45:56.211 -> ADC Value :159.00
    08:45:57.244 -> ADC Value :156.00
    08:45:58.321 -> ADC Value :160.00
    08:45:59.352 -> ADC Value :158.00
    08:46:00.425 -> ADC Value :159.00
    08:46:01.453 -> ADC Value :160.00
    08:46:02.485 -> ADC Value :158.00
    08:46:03.560 -> ADC Value :160.00
    08:46:04.591 -> ADC Value :157.00
    08:46:05.668 -> ADC Value :161.00
    08:46:06.698 -> ADC Value :156.00
    08:46:07.774 -> ADC Value :161.00
    08:46:08.800 -> ADC Value :156.00
    08:46:09.875 -> ADC Value :161.00
    08:46:10.905 -> ADC Value :155.00
    08:46:11.981 -> ADC Value :162.00
    08:46:13.014 -> ADC Value :155.00
    08:46:14.041 -> ADC Value :159.00
    08:46:15.112 -> ADC Value :151.00
    08:46:16.140 -> ADC Value :164.00
    08:46:17.215 -> ADC Value :153.00
    08:46:18.243 -> ADC Value :163.00
    08:46:19.318 -> ADC Value :151.00
    08:46:20.346 -> ADC Value :164.00
    08:46:21.423 -> ADC Value :152.00
    08:46:22.450 -> ADC Value :167.00
    08:46:23.525 -> ADC Value :151.00
    08:46:24.554 -> ADC Value :166.00
    08:46:25.631 -> ADC Value :152.00
    08:46:26.660 -> ADC Value :167.00
    08:46:27.736 -> ADC Value :153.00
    08:46:28.766 -> ADC Value :166.00
    08:46:29.840 -> ADC Value :151.00
    08:46:30.867 -> ADC Value :165.00
    08:46:31.941 -> ADC Value :151.00
    08:46:32.972 -> ADC Value :166.00
    08:46:34.000 -> ADC Value :151.00
    08:46:35.075 -> ADC Value :164.00
    08:46:36.104 -> ADC Value :153.00
    08:46:37.176 -> ADC Value :164.00
    08:46:38.203 -> ADC Value :151.00
    08:46:39.271 -> ADC Value :164.00
    08:46:40.343 -> ADC Value :151.00
    08:46:41.370 -> ADC Value :166.00
    08:46:42.445 -> ADC Value :152.00
    08:46:43.475 -> ADC Value :164.00
    08:46:44.551 -> ADC Value :150.00
    08:46:45.580 -> ADC Value :165.00
    08:46:46.610 -> ADC Value :151.00
    08:46:47.689 -> ADC Value :157.00
    08:46:48.713 -> ADC Value :154.00
    08:46:49.786 -> ADC Value :163.00
    08:46:50.816 -> ADC Value :151.00
    08:46:51.892 -> ADC Value :162.00
    08:46:52.919 -> ADC Value :153.00
    08:46:53.992 -> ADC Value :163.00
    08:46:55.019 -> ADC Value :152.00
    08:46:56.097 -> ADC Value :163.00
    08:46:57.125 -> ADC Value :152.00
    08:46:58.194 -> ADC Value :163.00
    08:46:59.219 -> ADC Value :152.00
    08:47:00.292 -> ADC Value :164.00
    08:47:01.324 -> ADC Value :150.00
    08:47:02.401 -> ADC Value :164.00
    08:47:03.429 -> ADC Value :151.00
    08:47:04.500 -> ADC Value :164.00
    08:47:05.526 -> ADC Value :152.00
    08:47:06.604 -> ADC Value :161.00
    08:47:07.634 -> ADC Value :154.00
    08:47:08.710 -> ADC Value :158.00
    08:47:09.737 -> ADC Value :157.00
    08:47:10.814 -> ADC Value :155.00
    08:47:11.842 -> ADC Value :159.00
    08:47:12.918 -> ADC Value :152.00
    08:47:13.949 -> ADC Value :163.00
    08:47:14.979 -> ADC Value :150.00
    08:47:16.048 -> ADC Value :165.00
    08:47:17.079 -> ADC Value :150.00
    08:47:18.156 -> ADC Value :164.00
    08:47:19.182 -> ADC Value :151.00
    08:47:20.256 -> ADC Value :161.00
    08:47:21.287 -> ADC Value :153.00
    08:47:22.361 -> ADC Value :156.00
    08:47:23.393 -> ADC Value :158.00
    08:47:24.470 -> ADC Value :155.00
    08:47:25.499 -> ADC Value :160.00
    08:47:26.571 -> ADC Value :151.00
    08:47:27.599 -> ADC Value :163.00
    08:47:28.672 -> ADC Value :150.00
    08:47:29.700 -> ADC Value :165.00
    08:47:30.772 -> ADC Value :146.00
    08:47:31.800 -> ADC Value :161.00
    08:47:32.876 -> ADC Value :154.00
    08:47:33.903 -> ADC Value :158.00
    08:47:34.977 -> ADC Value :158.00
    08:47:36.004 -> ADC Value :153.00
    08:47:37.078 -> ADC Value :162.00
    08:47:38.108 -> ADC Value :150.00
    08:47:39.140 -> ADC Value :164.00
    08:47:40.215 -> ADC Value :149.00
    08:47:41.244 -> ADC Value :162.00
    08:47:42.316 -> ADC Value :153.00
    08:47:43.344 -> ADC Value :159.00
    08:47:44.419 -> ADC Value :157.00
    08:47:45.446 -> ADC Value :154.00
    08:47:46.520 -> ADC Value :160.00
    08:47:47.547 -> ADC Value :150.00
    08:47:48.621 -> ADC Value :164.00
    08:47:49.654 -> ADC Value :149.00
    08:47:50.730 -> ADC Value :163.00
    08:47:51.759 -> ADC Value :150.00
    08:47:52.833 -> ADC Value :163.00
    08:47:53.863 -> ADC Value :152.00
    08:47:54.940 -> ADC Value :160.00
    08:47:55.967 -> ADC Value :156.00
    08:47:57.043 -> ADC Value :156.00
    08:47:58.071 -> ADC Value :159.00
    08:47:59.147 -> ADC Value :154.00
    08:48:00.176 -> ADC Value :163.00
    08:48:01.207 -> ADC Value :151.00
    08:48:02.282 -> ADC Value :165.00
    08:48:03.310 -> ADC Value :150.00
    08:48:04.386 -> ADC Value :161.00
    08:48:05.415 -> ADC Value :154.00
    08:48:06.490 -> ADC Value :157.00
    08:48:07.523 -> ADC Value :156.00
    08:48:08.602 -> ADC Value :155.00
    08:48:09.630 -> ADC Value :161.00
    08:48:10.704 -> ADC Value :152.00
    08:48:11.736 -> ADC Value :163.00
    08:48:12.763 -> ADC Value :149.00
    08:48:13.840 -> ADC Value :164.00
    08:48:14.870 -> ADC Value :149.00
    08:48:15.947 -> ADC Value :163.00
    08:48:16.975 -> ADC Value :150.00
    08:48:18.051 -> ADC Value :161.00
    08:48:19.077 -> ADC Value :152.00
    08:48:20.147 -> ADC Value :159.00
    08:48:21.176 -> ADC Value :155.00
    08:48:22.248 -> ADC Value :156.00
    08:48:23.272 -> ADC Value :157.00
    08:48:24.349 -> ADC Value :154.00
    08:48:25.378 -> ADC Value :160.00
    08:48:26.459 -> ADC Value :151.00
    08:48:27.490 -> ADC Value :162.00
    08:48:28.561 -> ADC Value :149.00
    08:48:29.590 -> ADC Value :163.00
    08:48:30.620 -> ADC Value :149.00
    08:48:31.693 -> ADC Value :163.00
    08:48:32.724 -> ADC Value :150.00
    08:48:33.799 -> ADC Value :161.00
    08:48:34.826 -> ADC Value :153.00
    08:48:35.903 -> ADC Value :159.00
    08:48:36.932 -> ADC Value :153.00
    08:48:38.005 -> ADC Value :151.00
    08:48:39.034 -> ADC Value :162.00
    08:48:40.107 -> ADC Value :153.00
    08:48:41.136 -> ADC Value :160.00
    08:48:42.209 -> ADC Value :152.00
    08:48:43.241 -> ADC Value :162.00
    08:48:44.316 -> ADC Value :150.00
    08:48:45.342 -> ADC Value :163.00
    08:48:46.415 -> ADC Value :149.00
    08:48:47.443 -> ADC Value :163.00
    08:48:48.515 -> ADC Value :149.00
    08:48:49.541 -> ADC Value :162.00
    08:48:50.618 -> ADC Value :151.00
    08:48:51.647 -> ADC Value :160.00
    08:48:52.723 -> ADC Value :153.00
    08:48:53.750 -> ADC Value :157.00
    08:48:54.822 -> ADC Value :156.00
    08:48:55.851 -> ADC Value :155.00
    08:48:56.923 -> ADC Value :159.00
    08:48:57.950 -> ADC Value :152.00
    08:48:59.025 -> ADC Value :161.00
    08:49:00.051 -> ADC Value :148.00
    08:49:01.124 -> ADC Value :158.00
    08:49:02.154 -> ADC Value :160.00
    08:49:03.230 -> ADC Value :164.00
    08:49:04.260 -> ADC Value :149.00
    08:49:05.333 -> ADC Value :158.00
    08:49:06.361 -> ADC Value :163.00
    08:49:07.435 -> ADC Value :152.00
    08:49:08.461 -> ADC Value :158.00
    08:49:09.538 -> ADC Value :151.00
    08:49:10.566 -> ADC Value :161.00
    08:49:11.596 -> ADC Value :149.00
    08:49:12.671 -> ADC Value :163.00
    08:49:13.701 -> ADC Value :149.00
    08:49:14.777 -> ADC Value :163.00
    08:49:15.804 -> ADC Value :150.00
    08:49:16.880 -> ADC Value :161.00
    08:49:17.907 -> ADC Value :153.00
    08:49:18.982 -> ADC Value :157.00
    08:49:20.008 -> ADC Value :158.00
    08:49:21.085 -> ADC Value :153.00
    08:49:22.113 -> ADC Value :161.00
    08:49:23.189 -> ADC Value :150.00
    08:49:24.223 -> ADC Value :163.00
    08:49:25.253 -> ADC Value :149.00
    08:49:26.331 -> ADC Value :162.00
    08:49:27.360 -> ADC Value :152.00
    08:49:28.434 -> ADC Value :157.00
    08:49:29.465 -> ADC Value :155.00
    08:49:30.539 -> ADC Value :155.00
    08:49:31.568 -> ADC Value :162.00
    08:49:32.643 -> ADC Value :150.00
    08:49:33.671 -> ADC Value :163.00
    08:49:34.747 -> ADC Value :150.00
    08:49:35.777 -> ADC Value :162.00
    08:49:36.849 -> ADC Value :152.00
    08:49:37.879 -> ADC Value :157.00
    08:49:38.953 -> ADC Value :157.00
    08:49:39.981 -> ADC Value :154.00
    08:49:41.056 -> ADC Value :161.00
    08:49:42.085 -> ADC Value :150.00
    08:49:43.116 -> ADC Value :163.00
    08:49:44.190 -> ADC Value :150.00
    08:49:45.216 -> ADC Value :162.00
    08:49:46.290 -> ADC Value :154.00
    08:49:47.315 -> ADC Value :156.00
    08:49:48.392 -> ADC Value :160.00
    08:49:49.419 -> ADC Value :151.00
    08:49:50.494 -> ADC Value :164.00
    08:49:51.519 -> ADC Value :150.00
    08:49:52.596 -> ADC Value :163.00
    08:49:53.623 -> ADC Value :152.00
    08:49:54.695 -> ADC Value :160.00
    08:49:55.720 -> ADC Value :156.00
    08:49:56.798 -> ADC Value :158.00
    08:49:57.827 -> ADC Value :160.00
    08:49:58.903 -> ADC Value :151.00
    08:49:59.932 -> ADC Value :163.00
    08:50:01.008 -> ADC Value :149.00
    08:50:02.031 -> ADC Value :163.00
    08:50:03.107 -> ADC Value :151.00
    08:50:04.133 -> ADC Value :161.00
    08:50:05.208 -> ADC Value :156.00
    08:50:06.237 -> ADC Value :156.00
    08:50:07.317 -> ADC Value :160.00
    08:50:08.343 -> ADC Value :152.00
    08:50:09.416 -> ADC Value :163.00
    08:50:10.437 -> ADC Value :150.00
    08:50:11.511 -> ADC Value :164.00
    08:50:12.538 -> ADC Value :151.00
    08:50:13.615 -> ADC Value :163.00
    08:50:14.642 -> ADC Value :154.00
    08:50:15.717 -> ADC Value :159.00
    08:50:16.744 -> ADC Value :158.00
    08:50:17.820 -> ADC Value :154.00
    08:50:18.846 -> ADC Value :162.00
    08:50:19.920 -> ADC Value :151.00
    08:50:20.946 -> ADC Value :164.00
    08:50:22.016 -> ADC Value :150.00
    08:50:23.050 -> ADC Value :164.00
    08:50:24.123 -> ADC Value :151.00
    08:50:25.150 -> ADC Value :162.00
    08:50:26.220 -> ADC Value :155.00
    08:50:27.243 -> ADC Value :158.00
    08:50:28.313 -> ADC Value :157.00
    08:50:29.376 -> ADC Value :155.00
    08:50:30.400 -> ADC Value :161.00
    08:50:31.477 -> ADC Value :152.00
    08:50:32.499 -> ADC Value :163.00
    08:50:33.565 -> ADC Value :151.00
    08:50:34.631 -> ADC Value :164.00
    08:50:35.656 -> ADC Value :151.00
    08:50:36.727 -> ADC Value :164.00
    08:50:37.751 -> ADC Value :151.00
    08:50:38.826 -> ADC Value :167.00
    08:50:39.855 -> ADC Value :153.00
    08:50:40.928 -> ADC Value :164.00
    08:50:41.958 -> ADC Value :150.00
    08:50:43.033 -> ADC Value :158.00
    08:50:44.063 -> ADC Value :142.00
    08:50:45.137 -> ADC Value :163.00
    08:50:46.164 -> ADC Value :151.00
    08:50:47.239 -> ADC Value :162.00
    08:50:48.270 -> ADC Value :155.00
    08:50:49.346 -> ADC Value :160.00
    08:50:50.373 -> ADC Value :156.00
    08:50:51.446 -> ADC Value :160.00
    08:50:52.473 -> ADC Value :156.00
    08:50:53.546 -> ADC Value :159.00
    08:50:54.576 -> ADC Value :156.00
    08:50:55.651 -> ADC Value :160.00
    08:50:56.682 -> ADC Value :157.00
    08:50:57.708 -> ADC Value :147.00
    08:50:58.779 -> ADC Value :157.00
    08:50:59.810 -> ADC Value :156.00
    08:51:00.882 -> ADC Value :160.00
    08:51:01.910 -> ADC Value :154.00
    08:51:02.974 -> ADC Value :163.00
    08:51:04.027 -> ADC Value :153.00
    08:51:05.071 -> ADC Value :164.00
    08:51:06.121 -> ADC Value :152.00
    08:51:07.175 -> ADC Value :164.00
    08:51:08.233 -> ADC Value :153.00
    08:51:09.289 -> ADC Value :164.00
    08:51:10.354 -> ADC Value :153.00
    08:51:11.377 -> ADC Value :158.00
    08:51:12.446 -> ADC Value :155.00
    08:51:13.510 -> ADC Value :157.00
    08:51:14.534 -> ADC Value :159.00
    08:51:15.603 -> ADC Value :156.00
    08:51:16.628 -> ADC Value :162.00
    08:51:17.697 -> ADC Value :153.00
    08:51:18.760 -> ADC Value :164.00
    08:51:19.780 -> ADC Value :152.00
    08:51:20.848 -> ADC Value :164.00
    08:51:21.878 -> ADC Value :154.00
    08:51:22.948 -> ADC Value :160.00
    08:51:24.018 -> ADC Value :159.00
    08:51:25.046 -> ADC Value :155.00
    08:51:26.075 -> ADC Value :163.00
    08:51:27.146 -> ADC Value :152.00
    08:51:28.221 -> ADC Value :165.00
    08:51:29.245 -> ADC Value :152.00
    08:51:30.318 -> ADC Value :163.00
    08:51:31.340 -> ADC Value :160.00
    08:51:32.410 -> ADC Value :158.00
    08:51:33.436 -> ADC Value :161.00
    08:51:34.501 -> ADC Value :153.00
    08:51:35.557 -> ADC Value :164.00
    08:51:36.619 -> ADC Value :152.00
    08:51:37.640 -> ADC Value :163.00
    08:51:38.709 -> ADC Value :157.00
    08:51:39.738 -> ADC Value :157.00
    08:51:40.813 -> ADC Value :162.00
    08:51:41.840 -> ADC Value :153.00
    08:51:42.914 -> ADC Value :165.00
    08:51:43.941 -> ADC Value :152.00
    08:51:45.019 -> ADC Value :162.00
    08:51:46.041 -> ADC Value :155.00
    08:51:47.116 -> ADC Value :159.00
    08:51:48.142 -> ADC Value :159.00
    08:51:49.218 -> ADC Value :155.00
    08:51:50.245 -> ADC Value :162.00
    08:51:51.320 -> ADC Value :153.00
    08:51:52.345 -> ADC Value :165.00
    08:51:53.421 -> ADC Value :152.00
    08:51:54.449 -> ADC Value :166.00
    08:51:55.521 -> ADC Value :154.00
    08:51:56.546 -> ADC Value :182.00
    08:51:57.624 -> ADC Value :155.00
    08:51:58.653 -> ADC Value :157.00
    08:51:59.726 -> ADC Value :162.00
    08:52:00.753 -> ADC Value :153.00
    08:52:01.829 -> ADC Value :165.00
    08:52:02.854 -> ADC Value :152.00
    08:52:03.933 -> ADC Value :165.00
    08:52:04.962 -> ADC Value :154.00
    08:52:06.039 -> ADC Value :160.00
    08:52:07.068 -> ADC Value :160.00
    08:52:08.144 -> ADC Value :156.00
    08:52:09.174 -> ADC Value :164.00
    08:52:10.247 -> ADC Value :152.00
    08:52:11.277 -> ADC Value :166.00
    08:52:12.306 -> ADC Value :153.00
    08:52:13.381 -> ADC Value :163.00
    08:52:14.408 -> ADC Value :158.00
    08:52:15.482 -> ADC Value :157.00
    08:52:16.512 -> ADC Value :164.00
    08:52:17.589 -> ADC Value :153.00
    08:52:18.616 -> ADC Value :166.00
    08:52:19.691 -> ADC Value :152.00
    08:52:20.718 -> ADC Value :163.00
    08:52:21.790 -> ADC Value :157.00
    08:52:22.818 -> ADC Value :158.00
    08:52:23.894 -> ADC Value :161.00
    08:52:24.922 -> ADC Value :154.00
    08:52:25.997 -> ADC Value :165.00
    08:52:27.025 -> ADC Value :152.00
    08:52:28.102 -> ADC Value :166.00
    08:52:29.132 -> ADC Value :153.00
    08:52:30.204 -> ADC Value :163.00
    08:52:31.233 -> ADC Value :157.00
    08:52:32.264 -> ADC Value :158.00
    08:52:33.338 -> ADC Value :162.00
    08:52:34.370 -> ADC Value :151.00
    08:52:35.445 -> ADC Value :163.00
    08:52:36.474 -> ADC Value :152.00
    08:52:37.549 -> ADC Value :164.00
    08:52:38.580 -> ADC Value :153.00
    08:52:39.656 -> ADC Value :161.00
    08:52:40.683 -> ADC Value :159.00
    08:52:41.759 -> ADC Value :157.00
    08:52:42.787 -> ADC Value :163.00
    08:52:43.861 -> ADC Value :154.00
    08:52:44.890 -> ADC Value :166.00
    08:52:45.965 -> ADC Value :152.00
    08:52:46.994 -> ADC Value :165.00
    08:52:48.069 -> ADC Value :154.00
    08:52:49.091 -> ADC Value :162.00
    08:52:50.165 -> ADC Value :159.00
    08:52:51.195 -> ADC Value :157.00
    08:52:52.229 -> ADC Value :164.00
    08:52:53.303 -> ADC Value :153.00
    08:52:54.332 -> ADC Value :166.00
    08:52:55.408 -> ADC Value :153.00
    08:52:56.438 -> ADC Value :164.00
    08:52:57.510 -> ADC Value :163.00
    08:52:58.539 -> ADC Value :155.00
    08:52:59.614 -> ADC Value :161.00
    08:53:00.640 -> ADC Value :156.00
    08:53:01.714 -> ADC Value :164.00
    08:53:02.741 -> ADC Value :155.00
    08:53:03.817 -> ADC Value :165.00
    08:53:04.845 -> ADC Value :156.00
    08:53:05.918 -> ADC Value :160.00
    08:53:06.948 -> ADC Value :168.00
    08:53:08.021 -> ADC Value :151.00
    08:53:09.051 -> ADC Value :161.00
    08:53:10.121 -> ADC Value :140.00
    08:53:11.146 -> ADC Value :154.00
    08:53:12.217 -> ADC Value :138.00
    08:53:13.239 -> ADC Value :167.00
    08:53:14.313 -> ADC Value :158.00
    08:53:15.384 -> ADC Value :161.00
    08:53:16.410 -> ADC Value :162.00
    08:53:17.482 -> ADC Value :156.00
    08:53:18.511 -> ADC Value :166.00
    08:53:19.584 -> ADC Value :153.00
    08:53:20.610 -> ADC Value :166.00
    08:53:21.683 -> ADC Value :157.00
    08:53:22.709 -> ADC Value :164.00
    08:53:23.781 -> ADC Value :156.00
    08:53:24.809 -> ADC Value :159.00
    08:53:25.878 -> ADC Value :162.00
  • Note that the arduino ADC inputs are high Z and  capacitive, and will drift all over if not solidly connected.  Also they will mis-read if the transient source impedance is not low enough, as the voltage then gets pulled about by the action of the internal ADC connecting its sampling capacitors  to the pin during the conversion cycles.
    So for tests to get stability to  bit 12, use a 1k pot between Vref and GND or if for power saving reasons your source impedance is more than a few k ohms decouple it with 10n or more to ground, so that during the read event, the voltage is still held more or less constant while the internal logic of the ADC switches things in and out to get its conversion compartors sorted.
  • The other thing I'm wondering about is "a sensor" - how noisy is the sensor (and as Mike suggests, what's its output impedance)? How noisy is the environment it's working in? E.g. if it's connected to a system involving a brushed motor (even if it's not directly connected to it) it won't be at all surprising if the signal bounces around like this. It's very typical that filtering, and possibly screening, is needed on the input and then averaging (effectively further filtering) needed on the ADC output. The sensor can, depending what and where it is, even pick up the clock frequencies from the arduino itself...
    What's also critical is how fast you need your result to be, crudely you want a big enough capacitor on the input so that the input rate of change is slowed down to the point where it's just not too slow!
    Welcome to the wonderful world of analogue Smiley
    Thanks,
    Andy
  • further to that watch the voltage gradient along the earthing- just because on the circuit it is all shown connected together, note that the sensor outputs a voltage between its pins, i.e relative to 'earth' at its location. The ADC measures between its pins, so relative to 'earth' at the arduino location. These may well be at opposite ends of an accidental wire antenna, and to  anything  that can measure a voltage in micro-seconds, then the ends of  a few feet  of wire can easily be some tens to hundreds of mV apart. So if adding capacitance to the line to filter, it needs to be at the ADC end, and with a definite resistance in series to give it something to chew on. Or better bring the earth along the same path as the signal, concentrically (coax) so that the two sides of the signal experience pretty much  the same disturbances.
    There is a very good reason really delicate or fast signals are sent down lines as differential signals ;-)
  • It's a vacuum sensor, noise wise it's not in any kind of production environment, I'm testing it in an office environment at the minute.
    I have now got it mostly running,
    13:25:07.389 -> Vacuum Sensor Voltage :4.47
    13:25:08.420 -> ADC Value :906.00
    13:25:10.431 -> Vacuum Sensor Voltage :4.42
    13:25:11.503 -> ADC Value :914.00
    13:25:13.508 -> Vacuum Sensor Voltage :4.46
    13:25:14.536 -> ADC Value :920.00
    13:25:16.546 -> Vacuum Sensor Voltage :4.49
    13:25:17.575 -> ADC Value :922.00
    13:25:19.583 -> Vacuum Sensor Voltage :4.50
    13:25:20.655 -> ADC Value :918.00
    13:25:22.655 -> Vacuum Sensor Voltage :4.48
    13:25:23.683 -> ADC Value :905.00
    13:25:25.672 -> Vacuum Sensor Voltage :4.42
    13:25:26.739 -> ADC Value :920.00
    13:25:28.730 -> Vacuum Sensor Voltage :4.49
    13:25:29.796 -> ADC Value :910.00
    13:25:31.784 -> Vacuum Sensor Voltage :4.44
    13:25:32.847 -> ADC Value :895.00
    13:25:34.846 -> Vacuum Sensor Voltage :4.37
    13:25:35.874 -> ADC Value :915.00
    13:25:37.883 -> Vacuum Sensor Voltage :4.47
    13:25:38.958 -> ADC Value :908.00
    There's variability in the ADC value which is changing the perceived pressure a lot, presumably because it's a log scale, so I'm considering upping the ADC spec, I'm limited now to 10 bit resolution by the arduino but I can get hold of an adaptor board to up this to 16, which should smooth out a lot of the variability I'm seeing.
    But I've taken on board everyone's comments and thrown a cap on the input.
    At the minute the first one I came to was a 0.1uF 50V cap, with that it now looks like this:
    13:30:18.637 -> Vacuum Sensor Voltage :4.46
    13:30:19.660 -> ADC Value :913.00
    13:30:21.663 -> Vacuum Sensor Voltage :4.46
    13:30:22.738 -> ADC Value :914.00
    13:30:24.736 -> Vacuum Sensor Voltage :4.46
    13:30:25.763 -> ADC Value :913.00
    13:30:27.768 -> Vacuum Sensor Voltage :4.46
    13:30:28.840 -> ADC Value :914.00
    13:30:30.806 -> Vacuum Sensor Voltage :4.46
    13:30:31.878 -> ADC Value :914.00
    13:30:33.886 -> Vacuum Sensor Voltage :4.46
    13:30:34.912 -> ADC Value :913.00
    13:30:36.914 -> Vacuum Sensor Voltage :4.46
    13:30:37.984 -> ADC Value :914.00
    13:30:39.987 -> Vacuum Sensor Voltage :4.46
    13:30:41.013 -> ADC Value :913.00
    HUGE DIFFERENCE.
  • Haven't I got around that though by connecting one of the ground pins to the ground connection from the PSU?
    The arduino is still connected via it's USB cable for power which will have a seperate ground, but by adding this wire I thought I'd be all good there, unless I've now created ground loops :/
