Use of 3D printing/additive manufacturing
Additive manufacturing/3D printing is now over 40 years old, with a multiplicity of technologies that can do amazing things.  Naturally, different materials and technologies are needed for different jobs, and not everything lends itself to be produced by AM/3DP.  However, the capabilities are real and proven, and the benefits of using AM/3DP are considerable.
So here's the question: what needs to be seen for AM/3DP to be used 10x more than it is now?
  • I would have thought the recent successful launch of a 3DP rocket into space would have gone a fair way to publicising the technology.
  • There are a few barriers to widespread adoption.
    • Amateur-grade kit is slow, noisy and smelly.  A print will take hours, or even days, to complete.  And the printers do occasionally catch fire.
    • Professional grade kit is expensive.
    • You need to understand 3D CAD to design your own parts.  And with print times in the hours, if you don't get it right first time, it takes a long time to do it again.
  • Here are some points that must be considered:
    - Type of printing technology (narrow down this multiplicity to where and how this will be used), eg: FDM for Fast Prototyping or SLS for end-use manufacture
    - Process control conditions (specific part specifications, temperature conditions [while printing & cool rate] and post-processing)
    - Printing material (different specifications) eg: ULTEM 9085
    - Certification of parts (test specimens, traceability, conformity, standards [ASTM & ISO)
    The key point is the Certification of parts i.e. qualifying them for their intended purpose, this is a by-product of the aforementioned points. The large proportion of dubiety is centred around quality and variability/consistency in the mechanical properties of parts. The dependency on these attributes is imperative for critical end-use applications to see the extension of  wide-spread 3D printing with the same credibility and assurance as other manufacturing processes, eg: injection moulding.
  • Agreed. Process certification and feedstock and manufactured part certification is still not fully mature. The ability to make structural parts to aerospace requirements is only just emerging
  • Thanks.
    Building on the point of certification, there are already myriad certification schemas.  What is needed for this concern to be eased?
  • Thanks.
  • there are already myriad certification schemas.  What is needed for this concern to be eased?
    It's often said (rather tongue in cheek) that the nice thing about standards is that there are so many to choose from... more seriously though, if there is a need for a 2nd or 3rd or 4th standard or certification system then an independent outside observe might suspect that the 1st (and 2nd and 3rd) weren't entirely up to the job. Confidence in the 4th of a similar ilk might not be high either.
  • Building on the point of certification, there are two key parent standards committees, these are:
    AMT/8 - Additive manufacturing - British Standards Institute
    Aerospace Materials Systems Group - Society of Automotive Engineers International
    Published or proposed specifications (eg: BS/ISO/CEN/ASTM) govern additive manufacturing activities such as:
    Applications, Design, Materials & Processes, Terminology & Test Methods
    The pertaining literature provides technical guidance on qualifying parts throughout there life-cycle and ultimately, quality of end-products. Please refer to the below "Reference Links" in furthering your research. Organisations may also set out to assure their products to ISO 9000 series quality management standards, noting that ISO 9000 has been developed by standards developed by ISO/TC 176
    Reference Links:
    https://standardsworks.sae.org/standards-committees/ams-additive-manufacturing
    https://standardsdevelopment.bsigroup.com/committees/50226095
    https://www.astm.org/products-services/standards-and-publications/standards/additive-manufacturing-standards.html
    ISO 9000:2015 - Quality management systems — Fundamentals and vocabulary
