Wind versus Coal
An interesting little side piece in E+T.  It will require 233  5 MW wind turbines to replace one 500 MW coal fired power station. This will occupy 55 square mile. This is also assuming quite a high capacity factor of nearly 43% but I will keep to the quoted numbers.
I am not sure if it is viable /sensible to build new coal fired power stations. The Chinese and the Indians certainly think that it is. So to look at the nuclear option:
To replace a 3 MW nuclear power plant with 2 EPR units, Hinkley point C or Sizewell C, will require 330 square miles to be filled with wind turbines (maybe more depending on the wake effect).
www.wind-energy-the-facts.org/wake-effect.html
This is more than twice the area of the Isle of Wight, not impossible but politically very difficult.
The more important question is the resources required. It is difficult to find numbers for the concrete and steel requirements for wind turbines. I do understand that this is affected by the ground conditions and foundation requirements however some number exist in this 2011 document.
pubs.usgs.gov/.../sir2011-5036.pdf
Table 5, page 12,  gives 100 tonnes of steel per MW and 400 tonnes of concrete per MW.  So to replace Hinkley Point C will, according to Kurt Cobb, require 6990 MW of wind turbines.
Steel 6990 * 100 tonnes  = 699 000 tonnes
Concrete 6990 * 400 tonnes = 2 796 000 tonnes.
The quoted figures for Hinkley Point C are:
Steel 280 000 tonnes
Concrete 3 000 000 tonnes.
https://www.newcivilengineer.com/innovative-thinking/projects-innovation-drives-hinkley-point-c-16-01-2019/
https://chamberuk.com/chrisfayers/
So similar amounts of concrete and a lot less steel for Hinkley Point C. The NPP has an expected life span of 80 years, wind seems to be typically 20-25 years.
Hinkley Point C could also use a lot less materials, cost less and be on time if it was built somewhere other than the UK:
www.spectator.co.uk/.../
Is wind power a sensible use of our finite resources?
  • Hello David:
    I have had a heat pump installed in my 70 year old house for over 30 years and they work great.
    However the house was built in 1970 to have just air-conditioning with the necessary cooling ducts built in. So it needed no retrofitting to replace with a heat pump.
    I can see situations in older houses, where adding heat pumps would not be a good idea.
    Peter Brooks
    Palm Bay Florida
  • One does wonder where this all leads?
    Well, the largest thing we leave for the future generations, in this case, and many others,  is the bill.
    Personally, I'm in a similar position to Simon, in terms of age and education, and have landed very much feet down. I'm not so sure my children will be able to say that at my age.
    I'd like to add an additional problem with property in the UK, as if we needed another, and that is the concept of leasehold. This allows a free holder to own the land under say a large block of flats, and collect rent and service charges  for it, while what the occupants buy for their  quarter million pound bedsit,  is actually only the right to live there for some fraction of 99 years, depending what the previous occupant, has used of the lease. That is not great but is not the main insidious problem as the lease can be renewed, but the sale of the freehold to someone with no real interest in maintaining the building, as the ground rent comes due if they do or not. This can leave leaseholders with a responsibility to pay, for something that in extreme cases,  may not even be habitable or saleable...
    The real problem is that there are a lot of folk making a living (== extracting money from something) without actually putting much effort in return, and worse, this behaviour is held up as some sort of ideal to aspire to.
  • Hello Mike:
    After WW11  in 1948 my parent (who never really talked about all the details) purchased an old home in London for a small amount as it only had 10 years left on the 99 year lease.
    Then the government changed the law to allow people to buy out the lease for again a very small amount of money. It thus became a very desirable property.
    Peter Brooks
    Palm Bay
    Florida
  • Hello Mike:
    It is my understanding that the land on which the IET headquarters building stands (Savoy Place) is owned indirectly by King Charles and a small token payment is made every year.
    Peter Brooks
    Palm Bay Florida
  • Hello Mike:
    There is currently a major problem in Florida (mainly in south Florida) with multi-story apartment buildings.
    After one condo collapsed a few years ago it was found to be due to a lack of building maintenance.
    The monthly fee paid by the apartment owners for general maintenance (grounds, swimming pool and common areas) was not enough to cover structural building maintenance (repair of roof and concrete columns being attacked by sea water).
    The state passed a law that buildings over a certain age and height had to be inspected and problems identified and priced.
    The condo association then has to impose additional fees on the owners to fix these problems.
    I hear that some condos owners now have outstanding bills for thousands of dollars and the owners are scrambling to sell, before the axe falls.
    Peter Brooks
    Palm Bay Florida
  • It seems crazy that laws have to be passed for common sense maintenance. In the uk the flammable cladding debacle is an example of enviromental do gooders imposing their judgement upon previously well designed buildings.
    Politics and profit first. Engineering second.
    Dumb.
  • Hello Jon:
    In the case of using flammable cladding on existing buildings, this was just a case of out and out fraud by the manufacturer and support from some Fire "Engineers".
    Peter Brooks
    Palm Bay Florida
  • Surely someone somewhere new the potential disaster?
  • Hello Jon:
    Oh yes some of them knew what they were doing, but the rest (Councils) just wanted the cheapest possible option.
    Peter Brooks
    Palm Bay Florida
    Perhaps, but I suggest your faith in folk being 'good' without an official standard is not supported as it seems we need other laws for common sense driving, and common sense food standards and so on as well  - it prevents the good guys being undercut and put out of business by the cheats and fraudsters.
    And in terms of looking after your buildings the whole Rachman empire was built on being a 'slum landlord' and being very careful to avoid local authority controls and he was not really found out until after his death  - its not a new problem
